DrawingArrangeDimensionsCmd for 2D Sketch
_KarlH
Message 1 of 1
_KarlH
Hey all,
Executing both DrawingArrangeDimensionsCmd and oDrawDim.CenterText within a Drawing IDW works well, but I'm struggling to find a similar method that arranges the dimensions of a 2D Sketch within a part (or the 3D Annotations of a part).
Searching these forums, I've found various topics that work with various sketch dimension/3D annotation aspects, but unfortunately don't touch on the actual problem of arranging existing messy 2D Dimensions.
Has anyone any technique to recommend for the arrangement of Dimensions within a 2D Sketch or 3D Annotations of a Part/Assy?
If there's no auto-magic method, one manual method I'm thinking of would be to cycle through 2D Dimensions that have a specific Dimension Name, and then group certain dims that match a naming schema and offset/space them out accordingly.
So for example, D1 could be named D1_OS1 (for offset group 1) and D2_OS2 (for offset group 2), and then both of those dimensions are offset by a multiplier according to their group, by using a For Each Item in ModelDims loop (and naming checking each dim).
I'm just not sure how to adjust the particular dimension objects to achieve the desired arrangement offset in a 2D Sketch. 🤔
Replies (0)
