ilogic and goexcel
ilogic and goexcel
viculises10
ilogic and goexcel
viculises10
Community Visitor
Community Visitor
Hi , Im trying to use ilogic to link values from excel to inventor. I don't get any errors but the code doesn't work.
I have two user parameters pipe size and pipe schedule and I have a cylinder with a parameter OD. My excel spread sheet has a column for Pipe sizes , next column is Pipe schedule and the last one is OD. The code is supposed to change the OD of the cylinder every time I update the parameters pipe size and pipe schedule but it doesn't do that. Because I don't get any errors i dont know whats wrong. attached are the excel file and the inventor ipart
A.Acheson
Hi @viculises10
I haven't had a chance to open the ipart. Would it be an easier approach to just use an ipart exclusively with no ilogic? Simply paste values direct to excel table of the ipart.
If you want to create an ilogic part please paste the code your using into the editor </> and we can see if the code is looking in the right locations.
Regards
Alan
Andrii_Humeniuk
Hi @viculises10 . You need to remove empty rows in your excel file. I also changed your code a bit, and added an event triggers to the change of user parameters.
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
