iLogic and Form question
tschaeferZNBXX
Advisor Advisor
Message 1 of 11
tschaeferZNBXX
We have a form that has some drop down and user filled in fields.  I would like to know if anyone can tell me how to "Grey out" some of the fields if certain selections are made?
Ideally if one selection is made from a drop down the other fields are not able to be edited.
Thomas "Matt" Schaefer
Engineering Tooling and Vault Manager for Material Handling Systems MHS
*AU Speaker 2018*
* AU Speaker 2017 *
Please use the "Accept as Solution" and "Give Kudos" functions as appropriate to further enhance the value of these forums.
Accepted solutions (3)
Replies (10)
Message 2 of 11
NSBowser
You can 'disable' a Form Entry field by connecting it to a (Boolean) 'Enabling Parameter' and then, using iLogic, setting the boolean to False when the logical condition arises, and True when the opposite condition arises.
Here is where you can link to the boolean.
Best of Luck
If you find this reply helpful or insightful, please use the 'Accept as Solution' or 'Kudos' button below.
Message 3 of 11
tschaeferZNBXX
That works but it is working opposite of what I want. If the selection is True I want the sections greyed out and able to be edited when False is selected.
*AU Speaker 2018*
* AU Speaker 2017 *
Message 4 of 11
NSBowser
You'll have to reverse your logic and set the boolean false to suppress, regardless of what your 'state' is. This might require you to create a new Boolean to handle the inversion.
Best of Luck
Message 5 of 11
tschaeferZNBXX
I cannot create or reverse the logic.
Do I need to write an entirely new iLogic rule?
*AU Speaker 2018*
* AU Speaker 2017 *
Message 6 of 11
smilinger
1. You need to create two boolean parameter, for example, like this:
2. Add this statement in your rule:
Enable_it = Not Disable_it
3. Use Enable_it to control your drop down list, and put Disable_it on the form.
Message 7 of 11
tschaeferZNBXX
Maybe I am totally miss understanding but this does not work.
*AU Speaker 2018*
* AU Speaker 2017 *
Message 8 of 11
smilinger
You also need to set the "Predefined Buttons" setting of your iLogic form to "Done", which means the selection you make on the form will be effective immediately.
Message 9 of 11
Jef_E
I think it's quite safe to say that iLogic forms arent ideal to have user interaction. It would be better ( in my humble opinion ) to use a AddIn for windows that react to whatever the user does. It's alot easier to do things there, and you can control almost every event you like to.
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Message 10 of 11
That works beautifully, thank you!
I was looking for a solution to be able to enable/disable form options.
Here's the peice of iLogic I used based on your explaination:
' If Double Door is selected then disable the Door Hinge Left/Right Option
If Door_Type = "Double Door" Then
Disable = True
Else
Disable = False
Enable = Not Disable
Message 11 of 11
tschaeferZNBXX
Thank you everyone for your help!
I was able to get this to work finally this morning!
*AU Speaker 2018*
* AU Speaker 2017 *
