Message 1 of 1
iLogic (and C#) color setting when exporting flatpattern to dxf
- Mute
- Permalink
- Report
I have used an iLogic code to export the flat pattern of a part to dxf.
I have used this piece of code:
Dim SaveLocatie As String SaveLocatie = ("C:\VaultWerkmap\ICN\Klanten\) System.IO.Directory.CreateDirectory(SaveLocatie) Dim sOut As String sOut = "FLAT PATTERN DXF?AcadVersion=R12&OuterProfileLayer=Contourlijnen" oDataIO.WriteDataToFile(sOut, SaveLocatie & OrderNo & ".dxf")
I found out, that I can set the AutoCAD version and the klayer names.
My question: is it also possible, to set the layer color in the dxf file for specific layers?
The same question, if I make code in C#.
Is it in C# possible to set the layer colors when exporting a flat pattern to dxf?
