ILOGIC ADD RULE IN ASSEMBLY!
HI!
It's possible to add rule in assembly with ilogic?
or to rule externalrule in assembly from a IDW?
Thanks for your help!
LukeDavenport
Hi Serge
You can create an iLogic rule with an iLogic rule as shown in my blog here:
https://inventorlogicblog.wordpress.com/2016/04/20/autodesk-inventor-ilogic-create-a-new-ilogic-rule...
Luke
Thanks for your reply Luke 🙂
Work really great in Document, but Do you think it's possible to run this externalrule in assembly from a IDW?
adam.nagy
Autodesk Support
Autodesk Support
Did you try? 🙂
Adam Nagy
Autodesk Platform Services
LukeDavenport
You might be pleasantly surprised Serge 🙂
Hi Luke 🙂
I have a little problem with your code, when i have no rule in my part or assembly i have this error message
Object reference not set to an instance of an object.
mr_ensing
I adapted the above mentioned code for use in the VBA editor.
This problem is fixed as well.
Sub AddInternalDummyRuleTest()
    Call AddInternalDummyRule(ThisApplication.ActiveDocument)
End Sub
Function AddInternalDummyRule(Doc As Document, Optional OverWrite As Boolean = False)
    'adapted from: https://inventorlogicblog.wordpress.com/2016/04/20/autodesk-inventor-ilogic-create-a-new-ilogic-rule-automatically/
    'define the iLogic addin
    Dim iLogicAddIn As ApplicationAddIn:    Set iLogicAddIn = ThisApplication.ApplicationAddIns.ItemById("{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}")
    'get the iLogic automation object
    Dim iLogic As Object:                   Set iLogic = iLogicAddIn.Automation
    'get the list of iLogic rules in the current Inventor document
    Dim RuleList As Object:                 Set RuleList = iLogic.Rules(Doc)
    Dim RuleName As String:                 RuleName = "DummyInternalRule"
    Dim RuleText As String:                 RuleText = ""
    'loop through all rules in document
    Dim Rule As Object
    If Not (RuleList Is Nothing) Then
        For Each Rule In RuleList
            If StrComp(Rule.Name, RuleName, vbTextCompare) = 0 Then
                    'a rule with the same name already exists...
                    Exit For
        Next Rule
    If Not (Rule Is Nothing) Then
        If OverWrite Then
            'delete the existing rule
            Call iLogic.DeleteRule(Doc, RuleName)
        Else
            Exit Function
    'add the new rule
    Call iLogic.AddRule(Doc, RuleName, RuleText)
End Function
