Button images location
Jef_E
Jef_E
Hi!
I'm creating an AddIn that works with parameters, and I would like to know where I can find the location of the images displayed on the buttons, so I can use these in my AddIn.
This would be very usefull because the user will associate with the image rather than be confused by using a new image.
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Owner2229
Hi, do you mean Thumbnail images? There's a blog about it on ModTheMachine:
Accessing Thumbnail Images
You have to scroll down a little, as the first code is VBA.
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Jef_E
No I mean this icons used for the ribbon buttons.
Inventor 2014 SP2
Owner2229
Hi, they're probably embed in the libraries, so you can't reach them.
But what you can do is take a screenshot of them and place it in new BMP file.
Mike
Jef_E
If I knew what librairy has them embed in them I could extract them. Screenshot is not 100% what I want to use but at the moment the best option.
Inventor 2014 SP2
