iLogic - Add row to BOM dependent on iProperty
lance_stevens1
lance_stevens1
Looking for help with some iLogic code.  I know there's a bunch of post about code for manipulating the BOM with iLogic.  But can't seem to find a post with this specific scenario.
Here's our objective:  Looking to add to rows into the BOM in an assembly.
Here's the setup:
The assembly will have 4 custom iProperties.  As follows...
Code 1 = YES or NO
Code1 QTY = some number
Code 2 = YES or NO
Code 2 QTY = some number
So a user will choose if Code 1 and Code 2 is YES or NO.  And they will manually fill out a Quantity.
So what I'm looking to do is... if Code 1 and/or Code 2 have a YES... then I want a row added to the BOM that says Code 1 for the name (or Code 2).  At this point, the Quantity would be applied as well.
Is this possible?
Ultimately, this needs to show up on a Parts List in a Drawing.  But I'd like it on the assembly, so it automatically shows up when a Parts List is pulled.
I know this could be done with Virtual Components.  But this won't fit the scenario in this particular Engineering/Design department.  These departments use Vault.  We want Code 1 & 2 (and quantities) to show up as properties in Vault.  So engineers can simply find the assembly in Vault and edit the Vault property (we'd obviously create a custom Vault property linked to the custom iProperty).
Any help would be appreciated!  Thanks so much!
HermJan.Otterman
you could add a virtual component.
would that be an option for you?
you can do that also with code
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
lance_stevens1
Thanks Herm... but my post mentions why virtual components are not a viable solution for their setup.  See below.
From my post:
Any idea what the iLogic code would look like for something like this?
HermJan.Otterman
ah, sorry for that.
Herm Jan
