iLogic add and constrain t-nut in t-slot.
Hi. We are working a lot with aluminum profiles from ITEM and also use their T-slot nuts.
In some assemblies there can be many t-nuts and its time consuming to mate them all.
Right now, just to get the t-nut in the slot, 2 - 3 constraints must be used.
I am looking for a solution to do this quicker.
Any ideas how this could be done? Was thinking the rule would add the nut to the assembly and wait for a user to select a feature or face on the alu-profile, then add all the constraints needed.
Has looked at some tutorials to get to know iLogic, but I dont think the basic features of iLogic can do this trick ?
Any help would be appreciated.
Using Inventor 2020
Daan_M
Have you looked into iMates? It's a functionality that could speed up the process.
https://www.youtube.com/watch?v=jTizrdBNZlw
This also doesn't require any iLogic knowledge, it's a tool in the standard Inventor UI.
dg2405
We make it this way 😉:
[video]
Thank you. I'll give this a try later.
