iLogic Activation Error and Content Center error
When I start program iLogic Activation Error show on display (see Pic)
when I click "OK"  I can access in program
I don't know this error affect to program or not
but 1 error I got is form Content Center , when I use "Bolt Connection" and click "Select a fastener Loading Content Center data..." then Error box is show (see pic.) and program is close
how I can solve tis problem,
Thank,
MjDeck
I'm not sure if the Content Center error is caused by this error.
To fix the error: close Inventor and then use Windows Explorer to delete the file named  user.config  in the folder:
C:\Users\user\AppData\Local\Autodesk,_Inc.\DefaultDomain_Path_x5nyxfubr3fxchypjp0dclw0mzyz0ig3\Autodesk®_Inventor®_2011
This filename is shown in the error dialog.
Mike Deck
Software Developer
Autodesk, Inc.
Thank you MIKE,
When i delete file  user.config  all problem solve
- iLogic error not shown when start
- Content Center in Bolt connection not error
Man Very Happy
I am getting the same error in windows xp.
I am searching the file user.config in Document & Settting but unable to find.
Can you please tell me where i can find the file user.config?
santosh
MjDeck
If you see the iLogic Activation Dialog, it should show the full directory name.  This would be near the top of the dialog.
In any case, the following procedure should get you to the file:
Start a Windows Explorer window, showing any folder on your system.
Copy and paste this into the address bar:
%USERPROFILE%\Local Settings\Application Data\Autodesk,_Inc.\DefaultDomain_Path_x5nyxfubr3fxchypjp0dclw0mzyz0ig3\Autodesk®_Inventor®_2011
On WIndows XP, %USERPROFILE% will probably be   C:\Documents and Settings\username
Mike Deck
Software Developer
Autodesk, Inc.
   When i try to create a tapped hole with Hole command in Inventor 2011, the thread options does not appear. Please find the image for the same. I have reinstalled the the software but still getting the same problem and hence i have to put threading annotations manually.
Please help me to resolve the issue.
Thanks.
MjDeck
Did you change anything on this computer?  Did threads work before in Inventor 2011 on this PC?
The threads data is stored in Excel format.  Do you have Excel installed on this computer?  Can you specify:
- Which version of Excel
- Which version of Windows
- 32 or 64 bit Windows?
To get the threads controls to appear, please try the steps (using regedit) in the attached excel.pdf file.
The pdf talks about  RegistryVersion12.0
Instead, to make it work in Inventor 2011 use RegistryVersion15.0
The full name of the registry value you have to edit is:
HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion15.0\System\Preferences\Part\UseExcelToReadThreadFile
Mike Deck
Software Developer
Autodesk, Inc.
