Ilogic / 2 Sketch Symbols libraries ... Global Form
mdavis22569
Mentor Mentor
mdavis22569
So here's my Ilogic question
Inventor 2016
So I have 2 different sketch symbol libraries .... One English and One in German.
My thought is (if it's possible) to make a global form that would be ... Sketch Symbols E ...and G ...    or when I click it, it asks me to pick either  E or G.  Then I'd be able to choose whatever Sketch Symbol I need (approx 30 in each) from the language I picked ...
Is this possible, or even worth researching ...
Thank you too ahead of time for your input and replies:
Mike Davis
Curtis_Waguespack
Hi mdavis22569,
This link has some code that deletes all of the un-used symbol definitons from the drawing and replaces them with the ones from a template file. I think you could do something like this and have all of the symbols swapped out by pointing it to a file that contains English symbols vs German symbols.
http://forums.autodesk.com/t5/inventor-customization/import-sketched-blocks-from-template/m-p/622824...
Or you could use something like the example at this link if you want to replace symbols that are in use on the drawing:
http://forums.autodesk.com/t5/inventor-general-discussion/ilogic-for-sketched-symbols/m-p/5842666#M5...
I hope this helps.
Curtis
