Ifeature Placement Two different Position Geometries
austen_27_t
Message 1 of 1
austen_27_t
I am trying to place an ifeature into a part with a specific position. The postition needs to be defined by the Sketch Plane which i already have and then an axis that is centered in the middle.  I do not know how to add another case where it will allow an axis to be selected.
I appreciate any help!
Public Sub directifeature()
'Activate part
On Error Resume Next
Dim partDoc As PartDocument
Set partDoc = ThisApplication.ActiveDocument
If Err Then
MsgBox "A part must be active"
Exit Sub
End If
Dim partDef As PartComponentDefinition
Set partDef = partDoc.ComponentDefinition
'Make sure face is selected
'Get the selected face to use as input for the iFeature.
Dim oFace As Face
Set oFace = ThisApplication.CommandManager.Pick(kAllPlanarEntities, "Pick a planar face")
Set oFace = partDoc.SelectSet.Item(1)
If Err Then
MsgBox "A planar face must be selected"
Exit Sub
End If
On Error GoTo 0
If Not oFace.SurfaceType = kPlaneSurface Then
Exit Sub
End If
Dim oFeat As PartFeatures
Set oFeat = partDef.Features
'Create iFeature Definition
Dim oIfeatDef As iFeatureDefinition
' Need to find a way to add revolve axis as selectable position geometry
'Set oIfeatDef = oFeat.iFeatures.CreateiFeatureDefinition("P:\Inventor\2014\iFeatures\Catalog\Slots\End_mill_curved.ide")
Set oIfeatDef = oFeat.iFeatures.CreateiFeatureDefinition("P:\Inventor\2014\iFeatures\Catalog\Slots\iFeature32.ide")
'Input data
Dim oInput As iFeatureInput
For Each oInput In oIfeatDef.iFeatureInputs
Dim ParaInput As iFeatureParameterInput
Select Case oInput.Name
'Will need to enter new case for the revolve axis here
Case "Sketch Plane1"
Dim oPlaneInput As iFeatureSketchPlaneInput
Set oPlaneInput = oInput
oPlaneInput.PlaneInput = oFace
Case "d2"
Set ParaInput = oInput
ParaInput.Expression = "1 in"
Case "d3"
ParaInput.Expression = "0.35 in"
End Select
Next
'Create Ifeature
Dim oiFeature As iFeature
Set oiFeature = oFeat.iFeatures.Add(oIfeatDef)
End Sub
Replies (0)
