iFeature: How to change affected bodies
ChrGBJ
ChrGBJ
Hello there!
I am trying to place an iFeature on a body selected with
Dim oFace As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFacePlanarFilter, "Select a planar face")
It is being placed, but for some reason not affecting the body of which i selected oFace
but it seems like it is cutting the first solid in the part hierarchy (There are multiple solids in the .ipt)
I have tried to change which SurfaceBodies are being affected with the following
Dim objects = ThisApplication.TransientObjects.CreateObjectCollection
objects.Add(oFace.SurfaceBody)
' Create the iFeature.
Dim oiFeature As iFeature
oiFeature = oFeatures.iFeatures.Add(oiFeatureDef) oiFeature.SetAffectedBodies(objects)
This changed nothing, then i tried to update the document
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.ActiveDocument
oPartDoc.Update()
And as you guessed, nothing...
I really don't know what to try next, and hope one of you could help me out
Thanks in advance
(Here is the full iLogic Rule, )
Public Sub Main()
  Dim oPartDef As PartComponentDefinition
  oPartDef = oPartDoc.ComponentDefinition
  ' Get the selected face to use as input for the iFeature.
  selectPointOne = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeMidpointFilter, "Vælg Midtpunkt 1")
  pointOne = oPartDef.WorkPoints.AddByMidPoint(selectPointOne)
selectPointTwo = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeMidpointFilter, "Vælg Midtpunkt 1")
pointTwo = oPartDef.WorkPoints.AddByMidPoint(selectPointTwo)
Dim oFeatures As PartFeatures
oFeatures = oPartDef.Features
' Create an iFeatureDefinition object.
Dim oiFeatureDef As iFeatureDefinition
oiFeatureDef = oFeatures.iFeatures.CreateiFeatureDefinition( _
"C:\Path\iFeature.ide")
' Set the input.
Dim oInput As iFeatureInput
For Each oInput In oiFeatureDef.iFeatureInputs
Dim oParamInput As iFeatureParameterInput
Select Case oInput.Name
Case "Face"
Dim oPlaneInput As iFeatureSketchPlaneInput
oPlaneInput = oInput
oPlaneInput.PlaneInput = oFace
Case "Point1"
Dim oPlaneInput As iFeatureEntityInput
oPlaneInput.Entity = pointOne Case "Point2"
oPlaneInput.Entity = pointTwo
End Select
Next
oPartDoc.Update()
End Sub
Used this as my guide:
  -  https://help.autodesk.com/view/INVNTOR/2020/ENU/?guid=GUID-8E822596-71C5-4C93-B935-7A6F04C7DE10
JelteDeJong
According to this post, this is a bug in the inventor API confirmed by Autodesk. But I noticed the following. If you hide all bodies except the body that you want to affect then it will work. This can easily be done by code. your code would then look something like this.
Dim selectPointOne = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeMidpointFilter, "Vælg Midtpunkt 1")
Dim pointOne = oPartDef.WorkPoints.AddByMidPoint(selectPointOne)
Dim selectPointTwo = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeMidpointFilter, "Vælg Midtpunkt 1")
Dim pointTwo = oPartDef.WorkPoints.AddByMidPoint(selectPointTwo)
Dim oFeatures As PartFeatures = oPartDef.Features
Dim oiFeatureDef As iFeatureDefinition = oFeatures.iFeatures.CreateiFeatureDefinition("C:\Path\iFeature.ide")
' Set the input.
        Case "Face"
        Case "Point1"
        Case "Point2"
    End Select
Next
Dim affectedBody = oFace.SurfaceBody
' Hide all bodies excpect the affectedBody
For Each body As SurfaceBody In oPartDef.SurfaceBodies
    If body Is affectedBody Then
        body.Visible = True
    Else
        body.Visible = False
    End If
Next
Dim affectedBoodies = ThisApplication.TransientObjects.CreateObjectCollection
affectedBoodies.Add(affectedBody)
Dim oiFeature As iFeature = oFeatures.iFeatures.Add(oiFeatureDef)
oiFeature.SetAffectedBodies(affectedBoodies)
' show all bodies again
    body.Visible = True
Next
oPartDoc.Update()
Jelte de Jong
Blog: hjalte.nl - github.com
ChrGBJ
I will try that, the next problem is that i would like too select two solids to be affected, and i assume that isn't possible, because of the bug.
JelteDeJong
I tried to do this with multiple bodies but that did not seem to work.. Maybe you have more luck.
Jelte de Jong
ChrGBJ
Thank you for your help, and sorry for the late reply. it definitely works better this way, but not as intended.
I hope it's okay i won't be accepting your fix as a solution, since i think this is something that should be fixed.
Maybe you know where i could report this?
thanks again.
MM5XZCAE
What if I want to select two or more surfacebodies for an iFeature? Kindly help
