If statement checking for multiple strings
will_roe
will_roe
I feel like this should be simple but I've searched all I can think of to do it correctly but can't find a answer. I just want a if statement to check to see if the first character is correct and show a message box and set a parameter if it's not.
I'm getting a 1-dimensional array of String'  error
ID_1_CHAR = IDTAG
Dim oID1 = Left((ID_1_CHAR), 1)
If oID1 <> {"H" Or "V" Or "H"} Then
MessageBox.Show("First character must be M, H or V", "Incorrect Input")
IDTAG = "H1234"
Thanks in advance.
dutt.thakar
@will_roe
When you use {} bracket it is identified as an array inside iLogic or VB.Net, that is why you are getting an error, as in the first-line you are defining a variable not an array, try below code instead and see if this helps you. You need to write like shown in Bold characters, to check multiple strings.
ID_1_CHAR = Parameter("IDTAG")
If (oID1 <> "H" Or oID1 <> "V" Or oID1 <> "H") Then
Parameter("IDTAG") = "H1234"
 Hope this helps.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
will_roe
@dutt.thakar
It doesn't seem to be working as expected - the message box shows with any input. It seems to work fine if I have a single variable like the below.
if  oID1 <> "H" Then
So I think I've misunderstood how the statement will work? Is the below just checking if oID1 doesn't = all of the values (H, V & M) So even if oID1 = H the statement will trip up because it doesn't = V or M?
If (oID1 <> "H" Or oID1 <> "V" Or oID1 <> "M") Then
This will work for my purposes but I'm wondering if there's a more elegant way to write it?
If (oID1 = "H" Or oID1 = "V" Or oID1 = "M") Then
'Insert code here
MessageBox.Show("It worked", "Title")
Else
dutt.thakar
@will_roe
Ok, I think below is another way which is quite easy to write (Using Select Case) and understand and may serve your purpose as well.
Select oID1 Case "H", "M", "V" MessageBox.Show("It worked", "Title") Case Else MessageBox.Show("First character must be M, H or V", "Incorrect Input")
Parameter("IDTAG") = "H1234" End Select
 See if this helps.
Dutt Thakar
LinkedIn
will_roe
Awesome, thanks @dutt.thakar !
