If Global Update (on) then run rule
My iLogic assy ig ok - ish  it will run.
After the first run the global update lights up & many things are wrong.
After a second run all is well 7 the Global Update switches off.
I'd like to automate running the rule until the Global update is Off.
How can I tell the state of the Global Update?
Ta
MES
Vladimir.Ananyev
You may check boolean Document.RequiresUpdate property value.
This property indicates if any of the entities within this document's scope is out of date with respect to its driving entities.
BTW  Sometimes it is convenient to run programmatically Inventor commands
(like RebuildAll / SaveAll / etc.)
Dim CommandName As String = "AppSaveAllCmd"
'Reference to CommandManager
Dim oCommandMgr As CommandManager = ThisApplication.CommandManager
'Reference to command definition
Dim oControlDef As ControlDefinition = oCommandMgr. _
   ControlDefinitions.Item(CommandName)
Call oControlDef.Execute() 'execute command
Beep  ' <-- can be removed
	' --- Popular commands ---
	'AppSaveAllCmd
	'AppCloseAllCmd
	'AssemblyRebuildAllCmd
	'PartRebuildAllCmd
	'AppRebuildAllWrapperCmd
 See this post for more detailes on Inventor commands:
 http://modthemachine.typepad.com/my_weblog/2009/03/running-commands-using-the-api.html
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
