If comparision doesn't work
Guido.LangeTuchscherer
Hello there,
I am trying to compare a parameter to the extent in X-Direction. The Values fit, but the statement doesn't do anything. So I guess I am mixing types?
What are theses Strings, Integer?
If Parameter("G_L") = Round(Measure.ExtentsLength, 0) Then
MsgBox("Länge identisch")
End If
JhoelForshav
@Guido.LangeTuchscherer
You should be able to compare that way... Are you sure they're the same?
Sometimes float values can be a bit difficult to compare. For example 100 could be interpreted as 100.000000000001 in the system. Therefore I'd recommend using DoubleForEquals to compare doubles.
See example below. First i make sure that they're in fact the same. Then I make the comparison:
MsgBox("ExtentsLength: " & Round(Measure.ExtentsLength, 0) & vbCrLf & _
"G_L: " & Parameter("G_L"))
If DoubleForEquals.IsEqual(Parameter("G_L"), Round(Measure.ExtentsLength, 0)) Then MsgBox("They're the same")
@JhoelForshav
Great thanks, now I just need the not equal equivalent or less than, how do you do those?
JhoelForshav
Something like this maybe? 🙂
Select Case True
Case DoubleForEquals.IsEqual(Parameter("G_L"), Round(Measure.ExtentsLength, 0))
MsgBox("Equal")
Case Parameter("G_L") > Round(Measure.ExtentsLength, 0)
MsgBox("G_L is greater than ExtentsLength")
Case Parameter("G_L") < Round(Measure.ExtentsLength, 0)
MsgBox("ExtentsLength is greater than G_L")
End Select
@JhoelForshav
Your solution works I just wonder why the if statements behave a bit strange:
aLength = Round(Measure.ExtentsLength, 0)
oLength = Parameter("G_L")
'Works
If DoubleForEquals.IsEqual(oLength, Round(Measure.ExtentsLength, 0)) Then MsgBox("They're the same") ' iProperties.Value("Custom", "Abmessungen") = "L = " & oLength & " mm"
'Does not work Else If oLength < Round(Measure.ExtentsLength, 0) Then MsgBox("They're not the same") End If
If oLength = aLength Then 'works
MsgBox("Länge identisch / Same length")
Else If oLength < aLength Then 'doesn't work
' iProperties.Value("Custom", "Abmessungen") = "L = " & Round(Measure.ExtentsLength, 0) & " mm"
MsgBox("Länge nicht identisch / different length")
End If
JhoelForshav
Your If-statements work fine for me... Are you sure the ExtentsLength isn't smaller than G_L when you try it? Because you have nothing handling that so that wouldn't return any messagebox at all...
@JhoelForshav
You are right i turned the operator < the wrong way, always test both ways to be sure....😉
