IDW Visibility of Body
halganabi
halganabi
I have IDW that has many Views of part X
Part X is multibody has bodies (A,B,C,D)
I need a code to turn off Visibily of a specific body in all views
the name of the body is entered by the user
jnowel
This should do the trick.
You can add another "For Loop" to apply the changes in all sheets instead of the ActiveSheet
Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oTrans As Transaction = ThisApplication.TransactionManager.StartTransaction(oDoc, "Hide Body") 'just added Transaction so you can undo easier
Dim oSheet As Sheet = oDoc.ActiveSheet
Dim sBodyName As String
sBodyName = InputBox("Enter Name of SurfaceBody to Hide", "IDW Visibility of Body", "Default Entry")
Dim iHit As Integer = 0
For Each oView As DrawingView In oSheet.DrawingViews
	If oView.DesignViewAssociative Then Continue For
	For Each oDrawCurve As DrawingCurve In oView.DrawingCurves
		'Dim oGeoParent As Object
		Dim oGeoParent As SurfaceBody
		oGeoParent = oDrawCurve.ModelGeometry.Parent
		If TypeOf oGeoParent Is SurfaceBody Then
			If oGeoParent.Name.ToUpper = sBodyName.ToUpper Then 'Added .ToUpper so entry is not case-senstive
				Logger.Info("Hidden " & oGeoParent.Name & " in " & oView.Name & " (" & oSheet.Name & ")")
				iHit += 1
				oView.SetVisibility(oGeoParent, False)
				Exit For
	Next
Next
If iHit > 0 Then
	MessageBox.Show("'" & sBodyName & "' hidden in all views (except in associative views)", "IDW Visibility of Body", MessageBoxButtons.OK)
Else
	MessageBox.Show("'" & sBodyName & "' NOT found in applicable views", "IDW Visibility of Body", MessageBoxButtons.OK)
oTrans.End
