Apply two DimensionTypeEnum's to a dimension
harvey_craig2RCUH
harvey_craig2RCUH
I wish to make this a diametric and a vertical dimension:
This is the main line in question, I would like to add kVerticalDimensionType to the DimensionTypeEnum but as you can see I already use that to make this diametric.
Dim SharpCornerDimension = genDims.AddLinear("SharpCornerDimension", oDrawingView.SheetPoint(1.2, 0.5), oIntersectionIntent, Detail_XAxis_Intent, kDiametricDimensiontype)
Is there a way for me to do both?
I have attached the files with the full rule included in the drawing.
Harvey
C_Haines_ENG
Are you able to set a dimension to two different styles normally? I don't think a dimension can be more than one dimension type.
The Inventor Documentation doesn't mention being able to enter more than one.
You can usually try putting multiple values into a slot like that by entering it like so:
{Enum1,Enum2,Enum3}
I doubt it will work for this but its worth a try.
harvey_craig2RCUH
Thanks for the attempt but no that didn't work.
I've tried simplifying by placing this on the main view but I get roughly the same result:
With the UI I select the exact same curves and give it the same options and it give me the correct result:
In my code my intent is the X axis, I don't see why Inventor doesn't see that as a line rather than a point and place the dimension in a perpendicular direction to it?
Harvey
Michael.Navara
You are not able to assign two dimension types. But after some investigation the result depends on correct arguments and its order. The picture bellow  show the order of selection for the code sample.
Dim drw As DrawingDocument = ThisDoc.Document
Dim drwSheet As Sheet = drw.ActiveSheet
Dim centerLine As Centerline = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCenterlineFilter, "Select center line")
Dim c1 As DrawingCurve = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "Select curve perpendicular to center line").Parent
Dim c2 As DrawingCurve = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "Select curve which defines the intersection").Parent
Dim midPoint As Point2d = c1.Segments(1).Geometry.MidPoint
Dim centerLineIntent As GeometryIntent = drwSheet.CreateGeometryIntent(centerLine)
Dim drawingCurvesIntent As GeometryIntent = drwSheet.CreateGeometryIntent(c1, c2)
Dim textOrigin As Point2d = midPoint.Copy()
textOrigin.TranslateBy(ThisApplication.TransientGeometry.CreateVector2d(1, 0))
Dim dimension As LinearGeneralDimension = drwSheet.DrawingDimensions.GeneralDimensions.AddLinear(
    textOrigin,
    drawingCurvesIntent,
    centerLineIntent,
    DimensionTypeEnum.kDiametricDimensionType)
harvey_craig2RCUH
Thank you Michael,
Very easy fix I just changed the order in my code and it worked perfectly.
Cheers again,
Harvey
