IDW to DWF Export Rule
layochim
Message 1 of 1
layochim
I'm failing forward on this rule to create a DXF from an IDW or DWG.
The DXF fille will be created but when i open it with AutoCAD LT i get a prompt to hit "Enter" and nothing happens.  Any assistance would be very helpful.  Code I'm using,
Sub Main()
	FileName = ThisDoc.FileName(True) 'with extension
	FileExtension = Right(FileName, 3)
	If FileExtension = "idw" Then
		Save_As_DXF
	Else If FileExtension = "dwg" Then
		Save_As_DXF
	Else
		ErrorMessage
End Sub
Sub Save_As_DXF
	oPath = ThisDoc.Path
	oFileName = ThisDoc.FileName(False)
	oDXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
	oDocument = ThisApplication.ActiveDocument
	oContext = ThisApplication.TransientObjects.CreateTranslationContext
	oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
	oOptions = ThisApplication.TransientObjects.CreateNameValueMap
	oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
	WorkspacePath = ThisDoc.WorkspacePath()													'Gets the workspace path
	WorkspacePathLength = Len(WorkspacePath)												'Gets the length of the workspace path string
	PathOnly = ThisDoc.Path																	'Gets just the path of the file
	DirectoryPath = Strings.Right(PathOnly, PathOnly.Length)			'Removes the workspace path from fullpath
	DXFPath = ThisDoc.Path								'Sets the directory that the pdf should be saved in
	DXFName = DXFPath & "\" & ThisDoc.FileName(False) & ".dxf"								'Saves the pdf in the desired location
	oDataMedium.FileName = DXFName
	oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintCurrentSheet
	If Not System.IO.Directory.Exists(DXFPath) Then											'checks to see if that directory exists, if not, it is created
		System.IO.Directory.CreateDirectory(DXFPath)
	oDXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
End Sub
Sub ErrorMessage
	i = MessageBox.Show("This Is Not a drawing File. No DXF will be created.", "Create DXf", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
End Sub
Replies (0)
