Error writing to excel
I have a program that opens an excel file with a number of parameters and iterates through the list, opening a database and checking if the database has a part that matches that description. If it does, it checks if the C drive contains that part. Parts that don't exist get added to a list for the user to make. Parts that do exist but aren't on the c drive get added to a "getter" string to copy into vault.
If the part exists, I'd like to write to the excel file the path. A second rule can then be run that takes the orientation and location and inputs the part and auto constrains it into my assembly.
Everything works except the writing portion. Originally this was all one rule and I wasn't checking the c drive for the part. This meant that you'd have to run the program once, it would tell you all parts missing from your c drive, you'd have to delete everything you just added out and do the get, then run it again.
By adding the writing portion, it meant I wouldn't have to re- search for every part, I could just run down the list and add them in. Unfortunately, while the program has no issue reading from 2 separate files, it has issue writing to a file, as it keeps telling me the excel sheet is already open and if I open it again it will lose all my changes for every time I write. How do I tell it to write without reopening the file each time?
(Let me know if you need to see the individual functions. Errors are occurring on lines 64 & 68)
Thank you
Sub Main
Dim FileName As String = "C:\TEMP\Coverplate Information.xlsx"
Dim LookupFile As String = "N:\Mechpart\TLONG\Parts Lists\INVENTOR COVER PLATES.xlsx"
Dim row As Integer = 1
Dim coverPlateType As String
Dim length As Double
Dim width As Double
Dim overhang As Double
Dim material As String
Dim plateName As String
Dim plateNumber As Integer = 1
Dim path As String
Dim partNumber As String
Dim coverPlateList As New ArrayList
Dim unFoundPlates As New ArrayList
Dim getPlates As New ArrayList
Dim coverPlatesFound As Boolean = True
Dim allFilesFound As Boolean = True
Dim unfoundPlateAdded As Boolean
Dim getPlateAdded As Boolean
GoExcel.Open(FileName, "Sheet2")
While Not GoExcel.CellValue(FileName, "Sheet2", "A" & row) = ""
'Set plate parameters
coverPlateType = GoExcel.CellValue(FileName, "Sheet2", "A" & row)
path = ""
partNumber = ""
If coverPlateType = "SURFACE" Then
overhang = .75
material = Parameter("CoverPlateThickness")
Else
material = "1/4 AL"
overhang = .9375
length = GoExcel.CellValue(FileName, "Sheet2", "B" & row) + 2 * overhang
width = GoExcel.CellValue(FileName, "Sheet2", "C" & row) + 2 * overhang
SortLengthWidth(length, width)
'See if new plate has already been added
path = CheckFoundPlatesAddedForPath(coverPlateList, material, length, width, coverPlateType)
If path = "" Then
i = GoExcel.FindRow(LookupFile, "Sheet1", "Length", "=", length, "Width", "=", width, "Material", "=", material, "Type", "=", coverPlateType)
If Not i = -1 Then
path = GoExcel.CurrentRowValue("Location")
partNumber = GoExcel.CurrentRowValue("Part Number")
coverPlateList.Add(New CoverPlate(material, coverPlateType, length, width, path, partNumber ))
'File has been created and is on C drive. Write location to excel sheet so program may go pick it up for insertion
If Not path = "" And System.IO.File.Exists(path) Then
GoExcel.CellValue(FileName, "Sheet2", "G" & row) = path
'File has been created but not on C drive. Check if in getter array and if not add it
Else If Not path = "" And Not System.IO.File.Exists(path)
getPlateAdded = CheckGetPlatesAdded(getPlates, partNumber)
If getPlateAdded = False Then getPlates.Add(partNumber)
allFilesFound = False
'File has not been created. Check if plate is in the unfound plates array and if not add it
Else
unfoundPlateAdded = CheckUnfoundPlatesAdded(unFoundPlates, material, length, width, coverPlateType)
If unfoundPlateAdded = False Then unFoundPlates.Add(New CoverPlate(material, coverPlateType, length, width, path, GoExcel.CurrentRowValue("Part Number")))
coverPlatesFound = False
plateNumber = plateNumber + 1
row = row + 1
End While
'Show cover plates that need to be made
If coverPlatesFound = False Then ShowCoverPlatesNeededMsg(unFoundPlates)
'Show cover plates that need a getter
If allFilesFound = False Then ShowGetPlatesMsg(getPlates)
GoExcel.Save()
GoExcel.Close()
End Sub
