IDW sheets to PDF by PDFAddIn - first 9 files are OK rest are 0 KB
radugc
radugc
When I print multiple sheets from IDW to PDF by using the PDFAddIn Translator, the first 9 files are good - the rest have 0KB. Is there any way to correct? Kind Thanks, Radu
xiaodong_liang
Autodesk Support
Autodesk Support
hi,
without a reproducible code, I am afriad the peers could have a comment. In addition, does this problem occur with any drawing (more than 9 sheets), or specific drawing? if with specific drawing, I would suggest you share a copy for diagnose.
Sometimes when I run my program that prints out PDF files, as the files are created in the folder I have open, some of them will show the file size, and others will show 0kb.  A simple right-click in the window and 'refresh' will show their true file size.  The file gets created, it's just Windows that doesn't refresh fast enough to get all the file data to display.
radugc
Thank you for looking into it - meanwhile, I have clarified my own mistake - I was not taking into consideration that the string sheet name changes the length when printing over 9 sheets - my document has 96 of them.  Thanks again, Radu
