How to access an AutoCAD file embedded in an IDW via VBA?
radugc
Message 1 of 9
radugc
Is there any way you can access an AutoCAD file embedded in an IDW by using VBA?
I have an IDW with about 100 sheets; it would like to control which file is embedded in each of the sheets.
The best would be to use linked files but I do not know how to make certain files visible on certain sheets.
Kind Thanks, Radu
Replies (8)
Message 2 of 9
xiaodong_liang
Autodesk Support
Autodesk Support
hi,
the embedded files are stored in Document.ReferencedOLEFileDescriptors. You can toggle its visibility by ReferencedOLEFileDescriptor.Visible.
The problem is : I do not see a way to know which sheet the referenced OLE file belongs to 😞
Message 3 of 9
radugc
Thank you for looking into it - see below the code I am using - an embedded object is inside the attached document - could you please explain the reason the count is zero - also, I could not see the Visible property. Thank you for help.
Option Explicit
Dim oApp As Inventor.Application
Public Sub OLE()
Set oApp = ThisApplication
Dim oDoc As Inventor.Document
Set oDoc = oApp.ActiveDocument
Dim oRefOLEFileDescriptors As Inventor.ReferencedOLEFileDescriptors
Set oRefOLEFileDescriptors = oDoc.ReferencedOLEFileDescriptors
MsgBox oRefOLEFileDescriptors.Count
End Sub
Message 4 of 9
xiaodong_liang
Autodesk Support
Autodesk Support
This is the snapshot at my side. It looks it works well. Which version of Inventor are you using?
Message 5 of 9
radugc
Hi, I am using 2009. Radu
Message 6 of 9
xiaodong_liang
Autodesk Support
Autodesk Support
ReferencedOLEFileDescriptors started to return OLE (embedded mode) from Inventor 2011. Before 2011, it only returns OLE (link mode).
Following is a workaround:
Sub ToggleEmbeddedObjectVisibility()
Dim bVisible As Boolean
bVisible = False
If MsgBox("Make visible?", vbYesNo) = vbYes Then
bVisible = True
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
' Get the "model" browser pane
Dim oPane As BrowserPane
Set oPane = oDoc.BrowserPanes.Item("DlHierarchy")
Dim o3rdPartyNode As BrowserNode
Set o3rdPartyNode = oPane.TopNode.BrowserNodes.Item("3rd Party")
Dim oNode As BrowserNode
Set oNode = o3rdPartyNode.BrowserNodes.Item("MM431 FLOW")
oDoc.SelectSet.Clear
Dim oCtrlDef As ButtonDefinition
Set oCtrlDef = ThisApplication.CommandManager.ControlDefinitions.Item("AppOLEVisibilityCmd")
If bVisible Then
oNode.Visible = True
oNode.DoSelect
' If the ButtonDefinition is "pressed", the item is already visible.
' Execute command only if invisible.
If Not oCtrlDef.Pressed Then
oCtrlDef.Execute
Else
oNode.DoSelect
' If the ButtonDefinition is "pressed", the item is visible.
' Make it invisible by executing the command.
If oCtrlDef.Pressed Then
oCtrlDef.Execute
'If you want to let the browser node disappear
oNode.Visible = False
End Sub
Message 7 of 9
radugc
We should get 2013 soon. Thank you for your support. Radu
Message 8 of 9
radugc
and I will try the workoround - Thanks again, Radu
Message 9 of 9
xiaodong_liang
Autodesk Support
Autodesk Support
forgot to comment: this code gets the browser node of the 'embedded', and execute the command to toggle its visiblity. The 'MM431 FLOW' is just the name of my demo. In your case, it is the name of your embedded file.
