*.idw saveas PDF 我有困惑
Message 1 of 14
QQ浏览器截图20180622153802.png大家好,我想用iLogic实现到idw转PDF,自定义的文件名遇见了问题,能不能帮我?Smiley Happy
NG Code
PDFPath = ThisDoc.Path
Dim Kubh As String=iProperties.Value("Project", "Stock Number")
ThisDoc.Document.SaveAs(PDFPath & "\" & ThisDoc.FileName(False) & " " & Kubh & (".pdf"),True)
ThisDoc.Document.Close
Replies (13)
Message 2 of 14
Xun.Zhang
Show you an example and hope it helps!
Please define the export file name as what you want then.
' This is an example iLogic rule by Luke Davenport on Cadline Community
' It creates a 'folder browser dialog' to allow user to pick a directory location
' This selected directory location is then used for a generic PDF export operation
' Please modify to suit your requirements....
Imports System.Windows.Forms
' Get current location of this file
Dim ExportPath As String = ThisDoc.Path
' Check that this file has been saved and actually exists on disk
If String.IsNullOrEmpty(ExportPath) Then
    MsgBox("This file has not yet been saved and doesn't exist on disk!" _
	& vbLf & "Please save it first",64, "Formsprag iLogic")
Return
End If
' Define folder browse dialog
Dim Dialog = New FolderBrowserDialog()
' Set options for folder browser dialog
Dialog.SelectedPath = ExportPath
Dialog.ShowNewFolderButton = True
Dialog.Description = "Choose Folder for Export..."
' Show dialog box
If DialogResult.OK = Dialog.ShowDialog() Then
    ' User clicked 'ok' on dialog box - capture the export path
    ExportPath = Dialog.SelectedPath & "\"
Else
    ' User clicked 'cancel' on dialog box - exit
    Return
End If
oFileName = iProperties.Value("Custom", "Sales Order Number")
' Define the filename of the file to be exported
' In this Case it Is a PDF file extension
ExportFilename = oFileName & ".pdf"
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
'set PDF Options
If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 1
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintSheetRange
End If
'Set the PDF target file name
oDataMedium.FileName = ExportPath & ExportFilename
Try
	'Publish document
	oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
Catch
	MessageBox.Show("Error writing out PDF", "iLogic")
	bError = True
End Try
If bError <> True Then
	'Ask user If they want To open (launch) the file we just exported...
	oMessage = "File exported: " & _
			ExportPath & ExportFilename & vbLf & vbLf & _
			"Do you want to open the PDF Now?"
	oQuestion = MessageBox.Show(oMessage, _
	"Formsprag iLogic - File Exported",MessageBoxButtons.YesNo)
	If oQuestion = vbYes Then
		ThisDoc.Launch(ExportPath & ExportFilename)
	End If
End If
Xun
Message 3 of 14
Smiley Mad
SyntaxEditor Code Snippet
我修改了这句就报错了
oFileName = iProperties.Value("Project", "Stock Number")
System.NullReferenceException: 无效指针 (Exception from HRESULT: 0x80004003 (E_POINTER))
在 Microsoft.VisualBasic.CompilerServices.LateBinding.LateGet(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack)
在 Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack)
在 ThisRule.Main()
在 Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
在 iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Message 4 of 14
Xun.Zhang
It looks a defect. @JaneFan, is it known for you?
Thanks!
Xun
Message 5 of 14
JaneFan
idw转PDF不能直接用inventor 文档的SaveCopyAs,需要调用inventor的TranslatorAddin来实现。这儿看,TranslatorAddin.HasSaveCopyAsOptions可能有点问题, 但是我们可以不用这个判断,直接调用。
以下是修改后的代码:
Dim oPDFAddIn As TranslatorAddIn
'set PDF Options
oOptions.Value("Sheet_Range") = PrintRangeEnum.kPrintSheetRange
Try
	'Publish document
	oPDFAddIn.SaveCopyAs(oDocument , oContext, oOptions, oDataMedium)
Catch
	bError = True
End Try
	End If
End If
Jane Fan
Inventor/Fusion QA Engineer
Message 6 of 14
抱歉试过不行,生成的PDF会跑到目录的上一级生成,而且生成的PDF文件名的也不对
Message 7 of 14
JaneFan
说明PDF文件导出成功了,跑到上一级文件目录以及文件名不对都是因为文件路径是要根据需要来改动代码的。
比如您最初的文件名是下面的字符串,那就根据需要改成这个就可以了。
您的文件名(根据代码猜测PDFPath和kubh应该都是在您自己的代码中已经定义过的变量名)
需要改动的代码:
Jane Fan
Message 8 of 14
不行的啊,库存编号读取不了
ExportFilename = ThisDoc.FileName(False) & " " & oFileName & ".pdf"
'set PDF Options
oDataMedium.FileName = ExportPath & "\" & ExportFilename
Try
	'Publish document
Catch
	bError = True
End Try
'If bError <> True Then
'	'Ask user If they want To open (launch) the file we just exported...
'	oMessage = "File exported: " & _
'			ExportPath & ExportFilename & vbLf & vbLf & _
'			"Do you want to open the PDF Now?"
'	oQuestion = MessageBox.Show(oMessage, _
'	"Formsprag iLogic - File Exported",MessageBoxButtons.YesNo)
'	If oQuestion = vbYes Then
'		ThisDoc.Launch(ExportPath & ExportFilename)
'	End If
'End If
Message 9 of 14
JaneFan
下面这句是读取库存编号的代码,是这行会报错吗?还是库存编号没有存入导出的文件名中?
 如果是库存编号没有存入文件名,请修改下面这句话使得oDataMedium.FileName满足您的需求。
Jane Fan
Message 10 of 14
*.ipt里的库存组件信息,*.idw就没读取到,造成保存的文件名没有库存编号
Message 11 of 14
JaneFan
模型文件里的库存信息不回自动到工程文件中,如果需要的话,需要在工程文件里通过如下语句设置一下,把VIEW1和Sheet1改成自己工程文档里面对应的名字。
iProperties.Value("Project", "Stock Number")  = ActiveSheet.View("VIEW1").ModelDocument.PropertySets.Item(3).Item("Stock Number").Value
 或者:
iProperties.Value("Project", "Stock Number")  = ThisDrawing.Sheet("Sheet:1").View("VIEW1").ModelDocument.PropertySets.Item(3).Item("Stock Number").Value
Jane Fan
Message 12 of 14
这样是可以了,但是他会在工程图里写内容,又没其他解决方案? 为何注解那些可以直接调用零件的库存编号?
Message 13 of 14
JaneFan
如果不想写入工程图的IProperties,直接读模型的属性写入需要的文件名就好了。根据需要调整代码吧:
oFileName = ThisDrawing.Sheet("Sheet:1").View("VIEW1").ModelDocument.PropertySets.Item(3).Item("Stock Number").Value
Jane Fan
Message 14 of 14
非常感谢,Smiley Happy
