Great start, well done!
I modified your script to work for all drawing views. Please note for some views it won't work. as maybe the two WP lay over each other.
Here also are some useful links.
http://hjalte.nl/37-auto-overall-dimension
http://hjalte.nl/77-adddimensionsdrawing
http://hjalte.nl/51-automatically-generate-bend-dimensions
http://hjalte.nl/40-hole-position-dimensions
Sub Main()
'Set reference to drawing document
Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
'Set reference to view and sheet
Dim oSheet As Sheet = oDoc.ActiveSheet
'Get reference to document in view
For Each oView As DrawingView In oSheet.DrawingViews
Dim viewDoc As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
Dim viewDocDef As ComponentDefinition = viewDoc.ComponentDefinition
'Dim viewNo As Integer = 3
Dim dimPt1 As String = "WP1"
Dim dimPt2 As String = "WP2"
Dim dimType As String = "Aligned"
'Dim dimText As String = "I made a dimension"
Dim DimYOffset As Integer = 1
Call AddLinearDim(oSheet,oView,viewDocDef, dimPt1, dimPt2, dimText, dimType, , DimYOffset)
Next
End Sub
Private Sub AddLinearDim(oSheet As Sheet,oView As DrawingView,viewDocDef As ComponentDefinition,dimPt1 As String, dimPt2 As String, dimText As String,
Optional dimType As String = "Aligned", Optional DimXOffset As Integer = 0, Optional DimYOffset As Integer = 0)
Dim sDimText As String = dimText & " <DimensionValue/>" & " TIP TO TIP"
'Get workpoints from the assembly document
Dim oWP1 As WorkPoint = Nothing : Dim oWP2 As WorkPoint = Nothing
Try
oWP1 = viewDocDef.WorkPoints.Item(dimPt1)
oWP2 = viewDocDef.WorkPoints.Item(dimPt2)
Catch
End Try
If oWP1 Is Nothing Or oWP2 Is Nothing Then MsgBox("WP1 Or WP2 is Nothing") :Exit Sub
'Place Centermarks where the Work Points reside
Dim oCM1 As Centermark = oSheet.Centermarks.AddByWorkFeature(oWP1, oView)
Dim oCM2 As Centermark = oSheet.Centermarks.AddByWorkFeature(oWP2, oView)
oCM1.Visible = False
oCM2.Visible = False
'Create Geometry Intent of the Centermarks
Dim oGeomIntent1 As GeometryIntent = oSheet.CreateGeometryIntent(oCM1)
Dim oGeomIntent2 As GeometryIntent = oSheet.CreateGeometryIntent(oCM2)
'Define Dimension Orientation variables
Dim dimTypeEnum As DimensionTypeEnum = Nothing
'Filter by dimension type
Select Case dimType
Case "Vertical"
dimTypeEnum = 60163
Case "Horizontal"
dimTypeEnum = 60162
Case "Aligned"
dimTypeEnum = 60161
Case Else
dimTypeEnum = 60161
End Select
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
'Declare variables for dimension endpoints
Dim oShtPt1 As Point2d = oView.ModelToSheetSpace(oWP1.Point)
Dim oShtPt2 As Point2d = oView.ModelToSheetSpace(oWP2.Point)
'*** Control where the Dimension Text is located
Dim oDimX As Double = oShtPt1.X + DimXOffset
Dim oDimY As Double = oShtPt1.Y + DimYOffset
Dim oPtText As Point2d = oTG.CreatePoint2d(oDimX, oDimY)
'*** Create the Dimension
Try
Dim oDimension As DrawingDimension
oDimension = oSheet.DrawingDimensions.GeneralDimensions.AddLinear(oPtText, oGeomIntent1, oGeomIntent2, dimTypeEnum)
oDimension.CenterText
'Add text to dimension
Dim MyDimText As DimensionText = oDimension.Text
MyDimText.FormattedText = sDimText
Catch
End Try
End Sub
