idw file data extraction
amitnkukanur
amitnkukanur
I am doing a project which is dependent on iProperties and is working well. However in one typical case i am required to extract data from IDW File BOM.
Is it possible to do so and if yes and reference is available.
rgds
Senior Software Engineer
Vladimir.Ananyev
You may use the following object’s relationships:
DrawingDocument => DrawingBOMs => DrawingBOM => DrawingBOMColumns and DrawingBOMRows collections and DocumentDescriptor object.
DrawingBOMRow => DrawingBOMCell => Value
DrawingBOMRow => BOMRow Property => (ItemNumber, ItemQuantity, TotalQuantity, etc.)
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
amitnkukanur
Hi Vladimir,
Thanks for reply. Will come back after working on this solution.
Hi Amitk
Did you find a solution to this ? I am working on the same task !
