iCopy iLogic equivalent
- Mute
- Permalink
- Report
Hey
I know there are lots of different ways to do things but I like the way iCopy works. Unfortunately it's not open to the api so working with it using automation isn't available...
Before I embark on an assembly build that will drive a range of product assemblies, I wondered if there was any good ilogic, vb.net code that I could be point toward and / or a reasonable workflow that could be used.
In summary, I have an assembly that has a collection of parts. The assembly will always be the same width and always have the same components, the top and bottom angles can change as well as the height.
My workflow thought for this is to use model states and create them on the fly or profile them and use as required but that would mean a lot of states per each part and assembly. Is there a better way and is there any similar ilogic code to icopy?
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
