iAssembly to control representations in members
mikko.m
mikko.m
I found this VB-code. How to edit this code so it would work in top-level iAssembly? I got the test model Casey provided to work but there the iAssembly is in sub-level.
_____________________________________________________________________________________
Inventor Professional 2019.3
Vault Workgroup 2019.1.1
JaneFan
Hello @mikko.m
Please activate the design view of top level assembly in this way:
Dim doc As AssemblyDocument
Set doc = ThisApplication.ActiveDocument
Call doc.ComponentDefinition.RepresentationsManager.DesignViewRepresentations.Item("View1").Activate
Jane Fan
Inventor/Fusion QA Engineer
mikko.m
@JaneFan
Where it should be inserted so it would change different views to members?
member-1 -> view1
member-2 -> view2
 Option Explicit
Private WithEvents oAssemblyEvents As AssemblyEvents
Public Sub init()
    Set oAssemblyEvents = ThisApplication.AssemblyEvents
End Sub
Public Sub terminate()
    Set oAssemblyEvents = Nothing
End Sub
Private Sub oAssemblyEvents_OnOccurrenceChange(ByVal DocumentObject As AssemblyDocument, ByVal Occurrence As ComponentOccurrence, ByVal BeforeOrAfter As EventTimingEnum, ByVal Context As NameValueMap, HandlingCode As HandlingCodeEnum)
    ' My Assembly only has one occurrence of the iAssembly
    Dim oAssemblyOcc As ComponentOccurrence
    Set oAssemblyOcc = DocumentObject.ComponentDefinition.Occurrences(1)
    If BeforeOrAfter = kAfter Then
        ' Check to see if we have an iAssemblyFactory
        If oAssemblyOcc.IsiAssemblyMember Then
            ' Choose the DVR based on the name of the iAssembly Member
            Select Case oAssemblyOcc.Definition.iAssemblyMember.Row.MemberName
                Case "member-1"
                    ' Check to make sure we do not set the DVR if it is already what we want, to avoid an infinite loop
                    If StrComp(oAssemblyOcc.ActiveDesignViewRepresentation, "View1") <> 0 Then
                        oAssemblyOcc.SetDesignViewRepresentation "View1", , True
                Case "member-2"
                    If StrComp(oAssemblyOcc.ActiveDesignViewRepresentation, "View2") <> 0 Then
                        oAssemblyOcc.SetDesignViewRepresentation "View2", , True
            End Select
End Sub
mikko.m
Could this be done with iLogic?
