I want to select desired line with Inventor api.
hayattangercekler2
hayattangercekler2
Using Inventor API, I create lines by opening a sketch in the inverter and giving the specified points. I am opening this sketch in an assembly file. In this assembly file, I want to do the line selection event, which I manually made over the sketch in the ipt file, using the inventor api. Is it possible to do this with api or with ilogic?
Dev_rim
Hi there,
You need to use SelectEvent and PreSelectEvent events. They are inside of SelectEvents. By using them, You can filter which type of objects will highlighted or not. And you can create your own filters. You have to create a filter for SketchLines.
As you see there is a parameter named DoHighlight. You can add event to your code (VB.net, c#, VBA all of them have this feature) and you can do some filter like this.
If PreSelectEntity Is Not SketchLine
     DoHighlight = True
Else
     DoHighlight = Fasle
and then you can use OnSelect event to get object that selected.
JustSelectedEntities returns the object(s) that you selected.
In SelectEvents object there is a property named 'SingleSelectEnabled'. If you make it True, it will allow user to select only one object.
Here is the Select event object.
Best Regards
Devrim
If my answer is solved your problem, please mark it as Solution
Freundliche Grüße / Kind Regards
CattabianiI
The follwing rule, select the second line in the selected sketch (select a sketch before running the rule!)
To select the desired instead the second one you have to define some criteria (e.g. SketchLine.Lenght or define an attribute in SketchLine.AttributeSets)
Dim doc As Document = ThisApplication.ActiveDocument
Dim selset As SelectSet
selset = doc.SelectSet
Dim sketch As Sketch = selset.Item(1)
' Open the sketch for edit.
' This is only required for drawing sketches, not part.
'sketch.Edit
Dim sl As SketchLine = sketch.SketchLines.Item(2)
selset.Clear
selset.Select(sl)
