I want to create a new parameter with Ilogic and calculate the total by applying the existing parameter value.
tkddud711
tkddud711
In the code below, the existing parameter (user parameter) value G_L is not applied. How can I fix the error code?
oMyParameter = ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
oParameter = oMyParameter.AddByExpression("costpermm", "50", UnitsTypeEnum.kUnitlessUnits)
oParameter = oMyParameter.AddByExpression("Cost", "costpermm ", UnitsTypeEnum.kUnitlessUnits)image.png
JhoelForshav
Hi @tkddud711
I take it you want something like this? 🙂
Dim oDoc As Document = ThisDoc.Document
Dim oUserParams As UserParameters = oDoc.ComponentDefinition.Parameters.UserParameters
Try
oUserParams("Cost").Expression = "costpermm * G_L/1mm"
Catch
oUserParams.AddByExpression("costpermm", "50", UnitsTypeEnum.kUnitlessUnits)
oUserParams.AddByExpression("Cost", "costpermm * G_L/1mm", UnitsTypeEnum.kUnitlessUnits)
End Try
oDoc.Update
dutt.thakar
@tkddud711  The legend @JhoelForshav  has already answered it, I have just seen that after posting the reply, so I am editing this. 🙂
Try this and see if it works, I assume you already have your parameter G_L created.
Dim oParam As UserParameters = ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
oParam.AddByExpression("Costpermm", "50" * oParam.Item("G_L").Value, "ul")
oParam.AddByExpression("Cost", "Costpermm", "ul")
Hope it helps.
If this has answered your question, please accept this as a solution.
Dutt Thakar
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
tkddud711
Great! Thank you!
