I need to exclude any blank iproperties stock number from existing sort.
i have a rule that works just need to exclude any part that doesn't have a stock number
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
oUOM = oDoc.UnitsOfMeasure
Dim oOccs As ComponentOccurrencesEnumerator
oOccs = oDoc.ComponentDefinition.Occurrences.AllLeafOccurrences
Dim oMass As Double = 0
Dim oOcc As ComponentOccurrence
For Each oOcc In oOccs
	        If iProperties.MaterialOfComponent(oOcc.Name) = "Steel, Mild" Then
                       If iProperties.Value(oOcc.Name, "Custom", "M/P") = "F" Or
                             iProperties.Value(oOcc.Name, "Custom", "M/P") = "M" Or
				    iProperties.Value(oOcc.Name, "Custom", "M/P") = "P" Then
				 oMass = oMass + iProperties.MassOfComponent(oOcc.Name)
			   End If
               End If
    Next
sMass =  oMass  & " " & oUOM.GetStringFromType(oUOM.MassUnits)
MessageBox.Show(sMass, "FABRICATED Steel, Mild")
Curtis_Waguespack
Hi @Anonymous
I think you can use a Continue For line to skip to the next occurrence.
I hope this helps.
Curtis
	If iProperties.Value(oOcc.Name, "Project", "Stock Number") = "" Then
		 Continue For 'skip to next oOcc
	End If
		End If
	End If
Next
You Da Man. works perfect
