I need help with ilogic.
Message 1 of 8
hi,
im working in ilogic and it anoy's me that my part updates with evry change in dimention, is there a way to add a button into the ilogic interface that lets me manualy update all of my dementions in one go?
Replies (7)
Message 2 of 8
mcgyvr
Something may be possible..
Can you share your code/ipt files,etc... so we can see the details of what you are working on?
Message 3 of 8
tobias_wiesendanger
If you are using a ilogic form to edit dimensions, you could change the type.
You then have to click apply or Ok. Otherwise nothing updates.
regards
Tobias
Message 4 of 8
yes i know how to make it a button but i dont know how to stop the automatic update and start a manual update.
id like to know how i do that.
Message 5 of 8
Curtis_Waguespack
Hi @Anonymous
Welcome to the Inventor community.
Note that programming questions of this type are better asked on the Inventor Customization forum :
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I've asked the moderators to move this topic to that forum.
As for you question, if your rule is local, meaning stored in the file rather than in an external folder, which I'm guessing it is... then you can likely remedy this by enclosing the parameter names as shown below:
This rule will trigger anytime Length or Width is changed
Length = Width *2
This rule will only trigger with Width is changed
Parameter("Length") = Width *2
Often I like to define the "blue" parameters as triggers as in this example,  so that I can glance at the top of the rule and know what will trigger the rule to run. Note that the oTrigger variable is a throw away and is not really doing anything, it's just getting the parameter value as a way to call the local parameter to trigger the rule... its the unenclosed blue parameter that is doing calling the rule to run.
'define the parameters that will trigger the rule
oTrigger = Length
oTrigger = Diameter
If Parameter("Length") > Parameter("Box_Length") Then Parameter("Length") = Parameter("Width") Else Parameter("Length") = Parameter("Box_Length")- 2 End If
Parameter("HolePattern") = Parameter("Diameter") +2
 I hope this helps.
Curtis
Message 6 of 8
thank you for the eplanation but it didnt anser my question.
i might just be saying it wrong.
so here is a second try.
in i logic if you change a parameter (example:from 100 to 260) in in the form section, it will automaticaly update from 100 to 260. i would like to change that. i would like to change more parameters in one go and update them at the same time.
Id like the activation to be a button.
i hope this helps
Message 7 of 8
tobias_wiesendanger
So thats what you want?
https://youtu.be/QCmvnDgeevQ
If not you should post your files, so we can have a look.
Message 8 of 8
Curtis_Waguespack
i hope this helps
Hi @Anonymous
I think tobias.wiesendanger answered your question then, if you set the form to use the OK Cancel Apply then you can choose when to update the model after the parameters have been changed in the form
Here I have a form with two model parameters named Count1 and Count2
When I open the the form the buttons are grayed out:
When I change Count1 and then click on Count2 (or use the tab key) the buttons become active, but the model does not update
At this point I can choose to click Apply to update the model  or I can choose not to click any buttons...
image.png..
If I choose not to click any buttons, I can change Count2, and then when I click either the Apply or OK buttons both parameters will be updated and the model will change.
If this still doesn't answer your questions, then providing an example file or example code to help understand your issue is likely the next step.
I hope this helps.
Curtis
