I logic rule for flatpaterns
Message 1 of 14
I have been looking on this forum for help, an iLogic rule for creating a drawing with flat patterns of multiple parts of an assembly, the rule will create a drawing sheet for each or multiple parts with flat pattern in it. this i will use as bending drawing, or any other method to create bending drawings for huge sheet metal parts in an assembly..?
Thanks in Advance
Replies (13)
Message 2 of 14
S_May
Hello @Anonymous
I can not fulfill them all.. Smiley Very Happy
But the sheet metal as a dxf to store from an assembly they see in the ilogic...
Message 3 of 14
S_May
DXF from IAM:
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
'get DXF target folder path
oFolder = oPath & "\" & oAsmName & " DXF Files"
'Check for the DXF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
End If
'- - - - - - - - - - - - -Component - - - - - - - - - - - -
'look at the files referenced by the assembly
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
'work the the drawing files for the referenced models
'this expects that the model has been saved
For Each oRefDoc In oRefDocs
iptPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "ipt"
'check that model is saved
If(System.IO.File.Exists(iptPathName)) Then
Dim oDrawDoc As PartDocument
oDrawDoc = ThisApplication.Documents.Open(iptPathName, True)
oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName))
Try
'Set the DXF target file name
Try
CustomName =iProperties.Value(oFileName, "Custom", "PF_PRT_ZNR")
Catch
CustomName ="XXX" 'Wert, wenn iPropertie PF_PRT_ZNR nicht existiert
End Try
oDataMedium.FileName = oFolder & "\" & CustomName  & " " & oFileName & ".dxf"
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oDrawDoc.ComponentDefinition
If oCompDef.HasFlatPattern = False Then
oCompDef.Unfold
Else
oCompDef.FlatPattern.Edit
End If
Dim sOut As String
sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_OUTER_PR​OFILE"
oCompDef.DataIO.WriteDataToFile( sOut, oDataMedium.FileName)
'just for check its works coretcly
'i=MessageBox.Show(oDataMedium.FileName, "Title",MessageBoxButtons.OKCancel)
'MessageBox.Show(i,"title",MessageBoxButtons.OK)
'If i=2 Then
'Exit Sub
'End If
oCompDef.FlatPattern.ExitEdit
Catch
End Try
oDrawDoc.Close
Else
End If
Next
Message 4 of 14
S_May
DXF from IPT:
    Dim oDoc As PartDocument
    oDoc = ThisApplication.ActiveDocument
    oCompDef = oDoc.ComponentDefinition
        oCompDef.Unfold
    Else
    End If
    Dim sOut As String
      If ExportInner = True Then
          sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_INTERIOR_PROFILES"
      Else
      sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_OUTER_PROFILE"
      End If
    ' Get document's full file name
    Dim sFname As String
    sFname = oDoc.FullFileName
    ' The file format will depend on the extension
    ' Set file name extension to ".DXF"
    sFname = Left$(sFname, Len(sFname) - 3) & "dxf"
    oCompDef.DataIO.WriteDataToFile( sOut, sFname)
End Sub
Message 5 of 14
Hi May,
Thanks for your support, but it didn't work well, i got the following error,
Error on Line 12 : 'oAsmDoc' is not declared. It may be inaccessible due to its protection level.
Error on Line 32 : 'oDataMedium' is not declared. It may be inaccessible due to its protection level.
Error on Line 43 : 'oDataMedium' is not declared. It may be inaccessible due to its protection level.
can you help me..?
Message 6 of 14
S_May
Hello @Anonymous,
We use with us in the company inventor 2016, as the rules work. Smiley Embarassed
Message 7 of 14
doug.johnston
I just tried this code in Inventor 2016 and I removed the "END SUB" command at the end of the code and it worked for me.
I will definitely be using this one immediately !!!
''IPT to DXF ILOGIC CODE
oCompDef.Unfold
Else
End If
Dim sOut As String
Else
End If
End Sub
It's not easy maintaining this level of insanity !!!!!
Message 8 of 14
doug.johnston
With this code it creates the DXF with the bend lines and fold "start & end" lines.
I use DXF's for waterjet programming and would love a "clean "outline/extents" file for that purpose.
Can someone modify this code to eliminate those lines from being exported ??
Thanks in advance,
Doug J..
p.s. - I'm a newbie at ilogic and don't have enough experience to change it myself.
Message 9 of 14
S_May
Hi @doug.johnston,
bitte testen Sie diese APP....
Message 10 of 14
S_May
... und diese APP
Message 11 of 14
w.pepping
And this app for free
Get control of your sheet metal files.
Download the app from matprop.com
Message 12 of 14
S_May
Hi @w.pepping
The app I had forgotten, which is also very good
Message 13 of 14
How would I set AcadVersion to R12? Also I need to merge profiles to polyline and rebase geometry to 1st quadrant.
I'm just now getting into iLogic and have inherited previous programming from a colleague who has since left.
Thanks in advance.
Message 14 of 14
Alternatively, if I could get iLogic to retrieve and use a configuration file and use that instead life would be so much better right now.
