I logic program for adding and constraining components but i don't know how to add multiple assembly with the same program
richie_rQYQ8U
richie_rQYQ8U
Hi All,
I write a program to add the components in an assembly and give constrains but I don't know how to add multiple assemblies with the same program i tried creating a panel number as integer and adding it to the name of my component but i ended up getting multiple panel like this. can anyone help me with this
Attached the code below
'Directing to the part folder
Dim PartsFolder As String = "Z:\Jobs-Quotes\Others\Ghost\Generative design\Seamless Balustrade\FFTM"
'Place Faceplate
Dim FaceplateComp = Components.Add("_Faceplate", PartsFolder & "/faceplate.ipt", position := Nothing, grounded := False, visible := True, appearance := Nothing)
'Place Baluster
Dim BalusterComp = Components.Add("_Baluster",  PartsFolder & "/seamless baluster.ipt", position := Nothing, grounded := False, visible := True, appearance := Nothing)
'get Height from FFL
Dim Handrail_height_from_FFL, Faceplate_to_FFL, Baluster_height_below_FFL As Double
Handrail_height_from_FFL = InputBox("Enter the Handrail height from FFL", "Height from FFL", 1100)
Baluster_height_below_FFL =  InputBox("Enter the Baluster height below FFL", "Height below FFL", 585)
Faceplate_to_FFL=  InputBox("Enter thedistance from Faceplate to FFL", "Faceplate to FFL", 120)
'Parameter Baluster
Parameter("_Baluster", "BalusterHeight_Above_FFL") = (Handrail_height_from_FFL-15)+Faceplate_to_FFL
Parameter("_Baluster", "BalusterHeight_Below_FFL") = Baluster_height_below_FFL - 3
'constrain Faceplate to baluster
Constraints.AddFlush("SideFlush_Faceplate_Baluster", "_Faceplate", "SideFlush_Faceplate", "_Baluster", "SideFlush_Baluster",
                     offset := 0.0, biasPoint1 := Nothing, biasPoint2 := Nothing)
Constraints.AddMate("BackMate_Faceplate_Baluster", "_Faceplate", "FrontMate_Faceplate", "_Baluster", "BackMate_Baluster",
                    offset := 0.0, e1InferredType := InferredTypeEnum.kNoInference, e2InferredType := InferredTypeEnum.kNoInference,
                    solutionType := MateConstraintSolutionTypeEnum.kNoSolutionType,
Constraints.AddFlush("TopFlush_Faceplate_Baluster", "_Faceplate", "TopFlush_Faceplate", "_Baluster", "XZ plane",
'Place Undercap
Dim Comp = Components.Add("_Undercap", PartsFolder & "/undercap.ipt", position := Nothing, grounded := False, visible := True, appearance := Nothing)
'Constrain Undercap
Constraints.AddMate("SideMate_Baluster_Undercap", "_Baluster", "SideFlush_Baluster", "_Undercap", "XY plane",
Constraints.AddMate("CentreMate_Baluster_Undercap", "_Baluster", "XY plane", "_Undercap", "YZ plane",
Constraints.AddFlush("TopFlush_Baluster_Undrecap", "_Baluster", "XZ plane", "_Undercap", "XZ plane",
                     offset := (Handrail_height_from_FFL-7.5)+Faceplate_to_FFL, biasPoint1 := Nothing, biasPoint2 := Nothing)
'Place Baluster Endcap
Dim BalusterBotEndcapComp = Components.Add("_BalusterBotEndcap", PartsFolder & "/seamless baluster bot ec.ipt", position := Nothing, grounded := False, visible := True, appearance := Nothing)
Constraints.AddUcsToUcs("Endcap_to_Baluster", "_Baluster", "origin", "_BalusterBotEndcap", "origin",
                            xOffset := 0, yOffset := -Baluster_height_below_FFL, zOffset := 0)
'Get number of balusters
Dim NumberOfBalusters As Double
NumberOfBalusters = InputBox("Enter the Number of Balusters", "Number of Balusters 1 - 15 max", 10)
'Pattern Baluster
Dim rectPattern = Patterns.AddRectangular("Baluster_pattern", {"_Baluster","_BalusterBotEndcap"}, NumberOfBalusters, -110, Nothing, "X Axis", columnNaturalDirection := True, rowCount := 1, rowOffset := 1.0 in, rowEntityName := "Y Axis", rowNaturalDirection := True)
Parameter("_Faceplate", "FacePlate_length") = NumberOfBalusters * 110
Parameter("_Undercap", "uc_ln") = NumberOfBalusters * 110
A.Acheson
Hi @richie_rQYQ8U
Can you show the browser with the manually added occurrences?  You can then use capture tool to add or if you can highlight what is wrong with the existing code vs what you actually want to achieve on screen then that will help alot.
Regards
Alan
richie_rQYQ8U
Hi Acheson,
Thank you for your reply
I don't know where it goes wrong with the code
I don't know how to change the parameter name for multiple inputs
And every time i add another assembly with this code the flush constrain changes
