I-logic How to write parameter value to property
T.Tomassen
T.Tomassen
Im making a I-logic part for a pipe
the idea is to select a Inch dimension for the pipe with te correct thickness.
when that is done i want that de properties are filled in automaticly
the code that i have written is :
'Pipe 1/8 Inch'
If Inch = "1/8" And Schedule = "10"
d0 = 1
iProperties.Value("Project", "Description") = "1/8 Inch - Schedule 10"
filling in the description works this way but i want to add length to it so it looks like this
Description = 1/8 Inch - Schedule 10 - Length ....
so i want that value of the length parameter (d2) is written in the property description.
Could anyone help me with this ?
richterBKSAC
Hey,
I would try the following:
iProperties.Value("Project", "Description") = "1/8 Inch - Schedule 10 - " & Parameter("d2")
Andrii_Humeniuk
Hi @T.Tomassen . I add to the description above.
'Pipe 1/8 Inch'
If Inch = "1/8" And Schedule = 10 Then
	d0 = 1
	iProperties.Value("Project", "Description") = Inch & " Inch - Schedule" & Schedule & " - " & Parameter("d2")
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
T.Tomassen
this works thanks for the fast reply
T.Tomassen
this works thanks for the quick reply
