Custom iLogic Form Button
e_frissell
Message 1 of 9
e_frissell
Searched the forums and I can't find an answer to this so I was wondering if it was possible to create a custom button for use on a form.  Essentially what I have is a form that allows you to select a raw material however not all of our raw materials have purchased part numbers so the script looks like the below.
What I'm wondering is if I can create a custom button for use on the form that would make the call to the function instead of the line if partnumber = "" then call function
An alternative is the custom button could be tied to a second iLogic rule which fires off the email as well.  Currently it's set up with a msgbox and the msgbox is kind of annoying so if there's a way to get rid of it that would be great, otherwise this will have to get rolled out to the group with the minor annoyance.
' Tons of script
if partnumber for material doesn't exist call function to create email
function:
msgbox with vbYesNo asking "do you want to create a request?"
if vbYes then ' push pre-defined email to outlook with material and size information
if vbNo then exit function
Replies (8)
Message 2 of 9
A.Acheson
Hi @e_frissell
I would think this block of code would just go into your existing block as an error catch statement. Having the user click another button would be duplicating the action elsewhere and involves an extra step. A message box question is  important to avoid running off emails without the user thinking or indeed forgetting to put in a material from available library. But if that isn't required then  comment out or delete as required.
Regards
Alan
Message 3 of 9
e_frissell
That's a good thought but all the sizes are pre-defined in multivalue list so an error never really exists.  The dynamic multivalue lists are a blessing and a curse because prior to the if horizleg < x or horizleg > x the most common error would be from changing from a small size to a big size - i.e. .5" angle to 4" angle and the websize wouldn't exist for that size thus no partnumber exists (alternatively a try-catch error would have roughly the same effect here) and pop up the msgbox.  The way it's coded now prevents 90% of that but would still prefer a button to run the email because it's easier than a msgbox popping up when you're in the middle of selecting the material.
Can't create that runs on update because every time the dynamic list would update the rule would run and it'd have the same functionality.  Only way I can think of to maintain the dynamic list (i.e. not changing the buttons to a continue/apply) but prevent the msgbox from inadvertently popping up is a separate button
	Else If verticalLeg = 8 Then
		If horizLeg < 4 Or horizLeg > 8 Or horizLeg = 5 Then horizLeg = 4
		If webWidth < .375 Or webWidth > 1 Then webWidth = .5
		MultiValue.SetList("horizLeg", 4, 6, 8)
			If horizLeg = 4 Then
				MultiValue.SetList("webWidth", .375, .5, .625, .75, 1)
				If webWidth = .375 Then epicMatMod = "0083"
				If webWidth = .5 Then epicMatMod = "0039"
				If webWidth = .625 Then epicMatMod = "0412"
				If webWidth = .75 Then epicMatMod = ""
				If webWidth = 1 Then epicMatMod = ""
			Else If horizLeg = 6 Then
				MultiValue.SetList("webWidth", .5, .625, .75, 1)
				If webWidth = .5 Then epicMatMod = "0010"
				If webWidth = .625 Then epicMatMod = ""
				If webWidth = .75 Then epicMatMod = "0616"
				If webWidth = 1 Then epicMatMod = "0019"
			Else If horizLeg = 8 Then
				If webWidth = .5 Then epicMatMod = "0750"
				If webWidth = .75 Then epicMatMod = "0752"
If partMaterial <> "HRS" Then
	MsgBox("Not Available")
	Exit Sub
MultiValue.SetValueOptions(True, DefaultIndex := 0)
Vert_leg = verticalLeg
Web = webWidth
Horiz_leg = horizLeg
epicorNumber = epicMatNumber & epicMatMod
visDesc = verticalLeg & " X " & horizLeg & " X " & webWidth & " - " & epicMatType & " - " & partMaterial
epicorParamNumber = epicorNumber
iProperties.Value("Custom", "Visual Part Number") = epicorNumber
iProperties.Value("Custom", "Visual Description") = visDesc
If Length > .1 Then
	extfeat.Suppressed = False
	ThisDoc.Document.ObjectVisibility.Sketches = False
If Len(epicorParamNumber) < 7 Then Call EpicAlert(verticalLeg, horizLeg, webWidth, epicMatType, partMaterial, epicorNumber, visDesc)
End Sub
Function EpicAlert(verticalLeg, horizLeg, webWidth, epicMatType, partMaterial, epicorNumber, visDesc)
	alert1 = MsgBox("Epicor number for selected material does not exist, do you need this size?", vbYesNo, "Alert")
	If alert1 = vbYes Then alert2 = MsgBox("Create request for material to be added to Epicor and template?", vbYesNo)
Message 4 of 9
A.Acheson
You could move the message box to the end of the code and just have a filter statement down there. If you really want a button just place an external rule into the local/global form and use this as the button to send your email.
Without seeing all the workflow it is hard to offer any assistance. Can you screen shot the form your using?
Regards
Alan
Message 5 of 9
e_frissell
@A.Acheson thanks, here's a screenshot of the form but I can't screenshot the code since it's about 400 lines of the same thing repeating over and over.  As you can see the form is the basic layout but it has the dynamic multivalue.setlist - i.e. when you change the size from C3 to CX the list changes which is the flow I'm looking for, as opposed to having ALL the channel sizes in one list.  What happens though is that when you change variable "Size" from one value to another the "Weight" doesn't update to one of the values on the list until the dropdown is selected.
Here's the form
Here's what happens when you change C3 to a different number
There is no C10x4.1 channel, thus the purchase part number doesn't exist, thus the prompt to send the email pops up.
What I'd like is the form to have a second button called "Material Request" that calls a function within the rule to create the email.  This would prevent the email prompt from popping up
On the other hand now that I typed all that out I just realized why you recommended a second rule - the second rule would run after the first one is complete.  Does the problem make sense?  Not sure if I explained it well enough... Alternatively would it be possible to have that rule run when the form is closed, but prior to the part being saved?  Wouldn't want a slightly different variation of the same problem as the prompt for the email is
if len(RawMaterialNumber) < 7 then call function RequestMaterial
Message 6 of 9
A.Acheson
Hi @e_frissell
To have the code run only once a method is to change the style of the form action button to Apply so you can select all the variables hit apply and then the code runs. If possible paste in the code to see what worflow the code is running. Otherwise it can be difficult to replicate what your seeing.
Regards
Alan
Message 7 of 9
e_frissell
That was one of the things I tried and found that it had the exact same issue except you had to hit apply for every change.  Like, the form defaults to C3x4.1 channel.  Hit the dropdown, select C5 channel but weight still shows the dropdown for C3 and 4.1 is selected.  Hit apply, list updates to C5 weight sizes (however 4.1 is still the active size).  No part record exists for C5x4.1 so msgbox opens.
It's kind of hard to explain without watching it but... notice how the form starts off with C3x4.1, when you can change the channel size to C5 the weight is still set to 4.1  and because there's no C5x4.1 it throws the material doesn't exist msgbox.  The way to fix this is to make the weight default to the first value if the weight for C3 doesn't equal 4.1, 5 or 6...except that's a lot of coding.  The next best alternative would be
If Size = C3 then
     If Weight < 4.1 or Weight > 6 then Weight = 4.1
Except other channel sizes have weights in between 4.1 and 6 so the frequency of the error is reduced but it's not really solved since something like C3x5.4 would trigger the alert (5.4 is a weight for C4).
I sort of solved it for angle iron but the amount of coding was frustrating and it doesn't work with C-Channel
Else If verticalLeg = 2.5 Then
		If horizLeg < 1.5 Or horizLeg > 2.5 Or horizLeg = 1.75 Or horizLeg = 2.25 Then horizLeg = 1.5
		If webWidth < .125 Or webWidth > .5 Then webWidth = .1875
		MultiValue.SetList("horizLeg", 1.5,2,2.5)
The entire code is here.  It's long
Public Sub Main()
Dim materialOption1 As String
Dim materialOption2 As String
Dim subOpt1 As Double
Dim subOpt2 As Double
Dim subOpt3 As Double
Dim subOpt4 As Double
Dim curPart As Inventor.PartDocument = ThisDoc.Document
Dim epicorNumber As String
Dim extfeat = Feature.InventorFeature("Extrusion1")
Dim epicMatMod As String
Dim visDesc As String
Dim partMaterial As String
Dim epicMatNumber As String = "351-0"
Dim epicMatType As String = "Channel"
oLibraryName = "Autodesk Material Library"
Dim assetLib As AssetLibrary
assetLib = ThisApplication.AssetLibraries.Item(oLibraryName)
extfeat.Suppressed = True
ThisDoc.Document.ObjectVisibility.Sketches = True
MultiValue.UpdateAfterChange = True
materialOption1 = "ASTM A36"
materialOption2 = "Aluminum"
MultiValue.SetList("channelMaterial", materialOption1, materialOption2)
If channelMaterial = materialOption1 Then
	'oLibraryName = "Autodesk Material Library"
	'Dim assetLib As AssetLibrary
	'assetLib = ThisApplication.AssetLibraries.Item(oLibraryName)
	ThisApplication.ActiveMaterialLibrary = assetLib
	iProperties.Material = "Steel ASTM A36"
	MultiValue.SetList("channelSize", "C3", "C4", "C5", "C6", "C7", "C8", "C9", "C10", "C12", "C15")
	If channelSize = "C3" Then
		Grip = .273
		Dim_d = 3
		subOpt1 = 4.1
		subOpt2 = 5
		subOpt3 = 6
		MultiValue.SetList("chanWeight", subOpt1, subOpt2, subOpt3)
		If chanWeight = subOpt1 Then
			Dim_bf = 1.41
			Dim_tw = .17
		Else If chanWeight = subOpt2 Then
			Dim_bf = 1.498
			Dim_tw = .258
		Else If chanWeight = subOpt3 Then
			Dim_bf = 1.596
			Dim_tw = .356
	Else If channelSize = "C4" Then
		Grip = 0.296
		Dim_d = 4
		subOpt1 = 5.4
		subOpt2 = 7.25
		MultiValue.SetList("chanWeight", subOpt1, subOpt2)
			Dim_bf = 1.584
			Dim_tw = .184
			Dim_bf = 1.721
			Dim_tw = 0.321
	Else If channelSize = "C5" Then
		Dim_d = 5
		Grip = 0.32
		subOpt1 = 6.7
		subOpt2 = 9
			Dim_bf = 1.75
			Dim_tw = 0.19
			Dim_bf = 1.885
			Dim_tw = 0.325
	Else If channelSize = "C6" Then
		Dim_d = 6
		Grip = 0.343
		subOpt1 = 8.2
		subOpt2 = 10.5
		subOpt3 = 13
			Dim_bf = 1.92
			Dim_tw = 0.2
			Dim_bf = 2.034
			Dim_tw = 0.314
			Dim_bf = 2.157
			Dim_tw = 0.437
	Else If channelSize = "C7" Then
		Dim_d = 7
		Grip = 0.366
		subOpt1 = 9.8
		subOpt2 = 12.25
		subOpt3 = 14.75
			Dim_bf = 2.09
			Dim_tw = 0.21
			Dim_bf = 2.194
			Dim_tw = 0.314
			Dim_bf = 2.299
			Dim_tw = 0.419
	Else If channelSize = "C8" Then
		Dim_d = 8
		Grip = 0.39
		subOpt1 = 11.5
		subOpt2 = 13.75
		subOpt3 = 18.75
			Dim_bf = 2.26
			Dim_tw = 0.22
			Dim_bf = 2.343
			Dim_tw = 0.303
			Dim_bf = 2.527
			Dim_tw = 0.487
	Else If channelSize = "C9" Then
		Dim_d = 9
		Grip = 0.413
		subOpt1 = 13.4
		subOpt2 = 15
		subOpt3 = 20
			Dim_bf = 2.433
			Dim_tw = 0.233
			Dim_bf = 2.485
			Dim_tw = 0.285
			Dim_bf = 2.648
			Dim_tw = 0.448
	Else If channelSize = "C10" Then
		Dim_d = 10
		Grip = 0.436
		subOpt1 = 15.3
		subOpt2 = 20
		subOpt3 = 25
		subOpt4 = 30
		MultiValue.SetList("chanWeight", subOpt1, subOpt2, subOpt3, subOpt4)
			Dim_bf = 2.6
			Dim_tw = 0.24
			Dim_bf = 2.739
			Dim_tw = 0.379
			Dim_bf = 2.886
			Dim_tw = 0.526
		Else If chanWeight = subOpt4 Then
			Dim_bf = 3.033
			Dim_tw = 0.673
	Else If channelSize = "C12" Then
		Dim_d = 12
		Grip = 0.501
		subOpt1 = 20.7
		subOpt2 = 25
		subOpt3 = 30
			Dim_bf = 2.942
			Dim_tw = 0.282
			Dim_bf = 3.047
			Dim_tw = 0.387
			Dim_bf = 3.17
			Dim_tw = 0.51
	Else If channelSize = "C15" Then
		Dim_d = 15
		Grip = 0.65
		subOpt1 = 33.9
		subOpt2 = 40
		subOpt3 = 50
		MultiValue.SetList(chanWeight, subOpt1, subOpt2, subOpt3)
			Dim_bf = 3.4
			Dim_tw = 0.4
			Dim_bf = 3.52
			Dim_tw = 0.52
			Dim_bf = 3.716
			Dim_tw = 0.716
epicMatMod = ""
If channelSize = "C12" And chanWeight =  25 Then epicMatMod = "0075"
If channelSize = "C10" And chanWeight =  30 Then epicMatMod = "0074"
If channelSize = "C10" And chanWeight =  25 Then epicMatMod = "0073"
If channelSize = "C10" And chanWeight =  20 Then epicMatMod = "0072"
If channelSize = "C10" And chanWeight =  15.3 Then epicMatMod = "0070"
If channelSize = "C9" And chanWeight =  20 Then epicMatMod = "0069"
If channelSize = "C9" And chanWeight =  15 Then epicMatMod = "0068"
If channelSize = "C9" And chanWeight = 13.4 Then epicMatMod = "0067"
If channelSize = "C8" And chanWeight = 18.75 Then epicMatMod = "0066"
If channelSize = "C8" And chanWeight = 13.75 Then epicMatMod = "0065"
If channelSize = "C8" And chanWeight =  11.5 Then epicMatMod = "0064"
If channelSize = "C7" And chanWeight = 14.75 Then epicMatMod = "0058"
If channelSize = "C7" And chanWeight = 12.25 Then epicMatMod = "0063"
If channelSize = "C7" And chanWeight = 9.8 Then epicMatMod = "0062"
If channelSize = "C6" And chanWeight =  13 Then epicMatMod = "0055"
If channelSize = "C6" And chanWeight = 10.5 Then epicMatMod = "0057"
If channelSize = "C6" And chanWeight = 8.2 Then epicMatMod = "0079"
If channelSize = "C5" And chanWeight = 9 Then epicMatMod = "0050"
If channelSize = "C5" And chanWeight = 6.7 Then epicMatMod = "0054"
If channelSize = "C4" And chanWeight = .25 Then epicMatMod = "0053"
If channelSize = "C4" And chanWeight = 6.25 Then epicMatMod = "0052"
If channelSize = "C4" And chanWeight = 5.4 Then epicMatMod = "0051"
If channelSize = "C3" And chanWeight = 6 Then epicMatMod = "0049"
If channelSize = "C3" And chanWeight = 5 Then epicMatMod = "0047"
If channelSize = "C3" And chanWeight = 4.1 Then epicMatMod = "0046"
	visDesc = epicMatType & " - " & channelSize & "x" & chanWeight & " " & " - " & materialOption1
If Length > .1 Then
End Sub
		If alert2 = vbYes Then
			Try
				oOApp = CreateObject("Outlook.Application")
				oOMail = oOApp.CreateItem(0)
			Catch
				MessageBox.Show("Error in request. Please email the request to e.frissell@linkeng.com", "Failed Error")
				Exit Function
			End Try
				strbody = "<p style='font-family:calibri;font-size:16'>" & _
							"This is an automated request for " & visDesc
							'"This is an automated request for " & partMaterial & " " & epicMatType & " with vertical leg " & verticalLeg & ", horizontal leg " & horizLeg & ", and web width " & webWidth & vbCrLf
				strbody += "<br /><br />"
				strbody += "Epicor Identifier - " & epicorNumber & vbCrLf
				strbody += "Visual Description - " & visDesc
		With oOMail
			.bodyformat = 2
			.To = "plzdon'temailme"
			.CC = ""
			.BCC = ""
			.Subject = "Epicor Material Request " & partMaterial & " - " & epicMatType
			.Display 'Toggle this for a Signature on/off
		End With
		With oOMail
			.HTMLbody = strbody & vbNewLine & .HTMLBody ' add the signature without losing the HTML-formatting of the signature
			'.Attachments.Add (FilePath & "\" & StockNum & ".jpg")
			'.Display 'Toggle ON to show the Email Window
		End With
		If alert1 = vbNo Or alert2 = vbNo Then Exit Function
End Function
There was also code that said if weight <> subOpt1 or weight <> subOpt2 or weight <> subOpt3 then weight = subOpt1 except that code didn't work, I think, due to conversion errors.  Couldn't get a double for equals to work and basically gave up on it.  Last ditch effort to prevent the box from popping up needlessly was to hide it in the if length > .1 statement
Message 8 of 9
A.Acheson
I haven't really had a chance to dive into the code but just from observation. There is a ilogic function available for parameter("ParameterName") which allows for more targeting of when the parameter changes, updating while the code is running or at the end etc.  This differs from the blue local parameter "ParameterName", where any change in the parameter triggers the rule so if you have multiple parameter changes in the form then it will trigger each and every time a parameter is change. Maybe you can see if that helps you out. For the weight parameter I would think that should be displayed as read only and not a list box type as the user doesn't select that correct?  That will eliminate one source of error.
Regards
Alan
Message 9 of 9
e_frissell
Thanks!  I wasn't aware of the parameter("ParameterName") option, I'll see if that can work but I think I'll have to live with the functionality the way it is right now.  Currently if the extrusion command is suppressed (i.e. length is < =.1) then the alert is disabled which won't prevent the pop-up all the time but it'll prevent it a majority of the time when initially creating the part.  For C-channel the weight is required as that's how steel C-channel is sized.  Which is different than aluminum C-channel that is sized based on the width and the flange height... Fun stuff
