I-Logic delete iproperties if they contain a text string
william
william
Hello
I am trying to write some code to look through the custom i-properties and if the name of the i-property contains the search term, then delete it.
So far I have got to here...
oCustomPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
oCustomPropertyName = (oCustomPropertySet.Name)
Dim searchTerm As String
searchTerm = "Item"
For Each oCustomPropertyName in oCustomPropertySet
	If InStr(1, oCustomPropertyName, searchTerm, CompareMethod.Text) >0 Then
		MessageBox.Show("We found it", "Debug")
	Else
		MessageBox.Show("We didnt find it", "Debug")
Next
The error i am getting is "Conversion from type 'Property' to type 'String' is not valid."
What am I doing wrong?
Regards
johnsonshiue
Hi William,
I have to take a guess. Probably, you need to declare a String variable to capture "CustomPropertyName" value. It is because "CustomPropertyName" itself isn't a String variable.
Many thanks!
Software Test Engineer
william
Hello @johnsonshiue
I have just tried that, I get the same error.
Dim oCustomPropertyName As String
oCustomPropertyName = CStr(oCustomPropertySet.Name)
Dim searchTerm as String
searchTerm = "Item"
For Each oCustomPropertyName In oCustomPropertySet
	Else
Next
Is the InStr command the best way of going about this? I originally took @Curtis_Waguespack code from an earlier post (https://forums.autodesk.com/t5/inventor-forum/how-to-remove-custom-iproperty-with-ilogic/td-p/436406...
but the ".contains" method doesnt seem to work if the search term is inside the string, eg. it will not pick up that "Item" is contained inside "Item8_Code"
so I found another post that I though would be applicable (https://forums.autodesk.com/t5/inventor-customization/code-vb-for-if-quot-value-quot-contains-quot-t...
Any help would be appreciated.
Curtis_Waguespack
Hi @william
This should work for you.
Also recall that there is the Inventor Customization forum , where programming questions of this type are better suited:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I'll ask the moderators to move this to that forum.
I hope this helps.
Curtis
searchTerm = "Item"
For Each oProp In oCustomPropertySet
	If oProp.name.Contains(searchTerm) Then
		MessageBox.Show("We found: " & oProp.name  _
		& vbLf & "Now we're going to delete it!", "iLogic")
		oProp.delete
Next
william
many thanks. That works great
