I have an .stl file that I want to turn into a solid
redondelosCRREA
redondelosCRREA
I have used the Mesh Enabler add-in to try and convert an .stl object into a solid that I can scale. However, all I get is a mesh feature that I cannot do basically anything with it. Is there a way to turn it into a solid .ipt or .stp object?
I attach both the .stl file and the converted-with Mesh Enabler file.
PD.: It would be useful if I could do this either in Inventor or Fusion360.
Stakin
Sub ImportFunc()
    ' Set STL translator's CLSID and STL file name.
    Dim strCLSID As String
    Dim strFileName As String
    strCLSld = "{81CA7D27-2DBE-4058-8188-9136F85FC859}"
    strFileName = "C:\Part1.stl"
    Dim oAddIns As ApplicationAddIns
    Set oAddIns = ThisApplication.ApplicationAddIns
    ' Find the Rhino translator, get the CLSID and activate it.
    Dim oTransAddIn As TranslatorAddIn
    Set oTransAddIn = oAddIns.ItemById(strCLSld)
    oTransAddIn.Activate
    ' Get the transient object and take it as a factory to produce other objects
    Dim transientObj As TransientObjects
    Set transientObj = ThisApplication.TransientObjects
    ' Prepare the first parameter for Open(), the file name
    Dim file As DataMedium
    Set file = transientObj.CreateDataMedium
    file.FileName = strFileName
    ' Prepare the second parameter for Open(), the open type.
    Dim context As TranslationContext
    Set context = transientObj.CreateTranslationContext
    context.Type = kDataDropIOMechanism
    ' Prepare the 3rd parameter for Open(), the options.
    Dim options As NameValueMap
    Set options = transientObj.CreateNameValueMap
    options.Value("SaveComponentDuringLoad") = False
    options.Value("SaveLocationIndex") = 0
    options.Value("ComponentDestFolder") = ""
    options.Value("ImportUnit") = 1
    options.Value("ImportColor") = True
    options.Value("ImportColorIndex") = 0
    ' Prepare the fourth parameter for Open(), the final document.
    Dim sourceObj As Object
    ' Open the STL file.
    oTransAddIn.Open file, context, options, sourceObj
End Sub
WCrihfield
Just dropping the Link in here to the Inventor API online help 'Sample' documentation for this, called "Open an STL file using the STL Translator Sample".
https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=ImportSTLslator_Sample
But just so you know, that example is in VBA, not iLogic or vb.net, and is designed for use from Inventor, not Fusion 360.
If you need it in a different programming language, such as for use in an iLogic rule, just let us know.
Wesley Crihfield
(Not an Autodesk Employee)
jjstr8
@redondelosCRREA - I'm not seeing any attachments. You should be able to right-click on the mesh feature and Convert to Base Feature
After that, you can do a Direct Edit to scale, move, or rotate.
