How would I write a rule for vertical post placement and number?
chris
Advisor Advisor
chris
I've set up a handrail generator and I'm trying to figure out how to write something that would determine the number of and placement of the vertical posts. (see image)
I'd like something that would allow me to access the total length of the shown handrail (One_Side_Length), it would then divide it by 72" and figure out the number has any remainder that it should add another vertical and then equally space all of them from one side to the other.
Example:
if the (One_Side_length) was 156" long, then it should know that 156/72=2.166666666, so I'd need 3 verticals, each equally spaced at 52".
I just don't know how to do the rounding and greater than/less than stuff
The two variables are:
Total Lenth:     (One_Side_Length)
Osha Spacing: (Osha_Spacing)
Curtis_Waguespack
Hi @chris
I think something like this would work. I did this in a part, but you could do the same in an assembly with a pattern.
I hope this helps.
Curtis
MaxLlength = 72
iCount = Ceil(One_Side_Length / MaxLlength)
Spacing = One_Side_Length / iCount
Count = iCount + 1
chris
@Curtis_Waguespack  WOW! this thing works great, doing some tests with it now, but it is doing what I want, thank you so much! HUGE help!!
