How use dll in iLogic?
Hubert_Los
Hubert_Los
I have created a .dll file. It works in VS Studio. But I can't use it in iLogic. How can I do this in iLogic?
AddReference "D:\Projects\dllSample.dll""
Dim oDll As New dllSample.dllClassName
oDll.dllFunctionName()
Michael.Navara
The code looks fine. Only one double quotes should be at the end of the first line
cidhelp
AddReference only accepts a DLL-Filename without path. The location is configured in the iLogic-Configuration.
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-32B66838-22E4-4A0A-B5BB-862350C76B36
Michael.Navara
Hi @cidhelp
The full path works as well. Maybe there can be some issues with references to the third party libraries if any, but reference to the single external DLL works.
Curtis_Waguespack
@Hubert_Los, if the previous suggestions do not resolve this for you, then you might review this AU class.
of particular note would be the iLogic + Class Library section
https://static.au-uw2-prd.autodesk.com/Class_Presentation_IM227119_Making_the_Leap_from_iLogic_to_Ad...
https://www.autodesk.com/autodesk-university/class/Inventor-iLogic-Beyond-Basics-2017#video
Hope that helps, Curtis
