How to use ThisApplication in Inventor
I think that is very popular question, but I have still have not found clear answer.
I have watch video about how to use ThisApplication in AutoCad.
Is it exist also so simple possibility in inventor?
I mean offcourse VB.net
How to use ThisApplication in VB.net?
I have understand how to do in AddIn. Here is part of code: Implements Inventor.ApplicationAddInServer Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate MsgBox("dll was started!") m_inventorApplication = addInSiteObject.Application appevents = m_inventorApplication.ApplicationEvents End Sub But if I want to create a dll that will be placed in: C:\Program Files\Autodesk\Inventor 2011\Bin\iLogicBin And later called like: AddReference "myvbdll" Is it possible to use ThisApplication in that dll?
MjDeck
Yes, you can use ThisApplication in a dll that will be referenced in an iLogic rule.
(Note that you you should put the dll in
C:\Program Files\Autodesk\Inventor 2011\Bin\iLogicAdd
instead of iLogicBin.)
To use ThisApplication in a dll:
- Add a reference to Autodesk.Inventor.Interop  to your VB.NET project.
- Add the line:
Imports Inventor
to your VB.NET source file
- Add a member to your VB.NET class:
Public ThisApplication as Inventor.Application
- In your rule, connect the predefined object named ThisApplication to that member variable:
Dim myClass As New MyVbClass()
myClass.ThisApplication = ThisApplication
Mike Deck
Software Developer
Autodesk, Inc.
Thank you - I have don't know about this part.
