How to use ilogic to measure length of edge ?
The problem is: I have a curved object, to know the length of this object, I proceed to use ilogic to measure the sides and get the appropriate length. when i perform edge measurement with measure tool in ilogic, i get this problem. can you help me? use ilogic
This object is a block imported from the *sat file, it will not have the feature...
JhoelForshav
Hi @Anonymous
I usually use CurveEvaluator to get the length of an edge. Are you looking for something like this? 🙂
'Get length of edge
Dim oEdge As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeFilter, "Pick edge.")
Dim oEval As CurveEvaluator = oEdge.Evaluator
Dim oMin, oMax, oLength As Double
oEval.GetParamExtents(oMin, oMax)
oEval.GetLengthAtParam(oMin, oMax, oLength)
'Display length in documents length units
Dim UoM As UnitsOfMeasure = ThisDoc.Document.UnitsOfMeasure
MsgBox(UoM.GetStringFromValue(oLength, UoM.LengthUnits))
Thanks you so much
