Get Sheetmetal active style from drawing
k14348
k14348
    i would like to collect part(Thisdrawing.modeldocument) sheetmetal active style detail from drawing through ilogic.
~K
WCrihfield
Here is something you can use:
Dim oMDoc As Document = ThisDrawing.ModelDocument
If TypeOf oMDoc.ComponentDefinition Is SheetMetalComponentDefinition Then
	Dim oSMDef As SheetMetalComponentDefinition = oMDoc.ComponentDefinition
	Dim oSMStyle As SheetMetalStyle = oSMDef.ActiveSheetMetalStyle
	MsgBox("oSMStyle.Name = " & oSMStyle.Name, , "")
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
