- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am looking for a way to create a few variables (including the Vault database logged in to) at the start of an Inventor session, which will be kept up to date during the session based on some event handlers (already functional in an iLogic-rule). These values are important because they determine whether triggered rules can be run or not. I want to avoid having to set this value over and over again, because it causes a noticeable delay for larger assemblies.
This must probably be an add-in, as iLogic doesn't seem to become functional until the first document is available. I have added references to several iLogic libraries.
Furthermore I thought the following should work, but apparently I lack some knowledge of VB.net. It's just a MyCode.addin and a StandardAddInServer.vb
Public Class StandardAddInServer
Implements Inventor.ApplicationAddInServer
'Application events object
Private WithEvents MyAppEvents As ApplicationEvents
Public ReadOnly SharedVariable As ISharedVariable
Public Sub Activate(AddInSiteObject As ApplicationAddInSite, FirstTime As Boolean) Implements ApplicationAddInServer.Activate
MessageBox.Show("At the beginning of ApplicationAddInServer.Activate")
If Not SharedVariable.Exists("ActiveDatabase") Then
SharedVariable("ActiveDatabase") = "Test"
End If
MessageBox.Show("At the end of ApplicationAddInServer.Activate")
End Sub
End Class
AddIn is loaded. Messageboxes are shown. How to correctly approach the ISharedVaribale interface is a mystery to me.
Can someone give me a push in the right direction?
Thanks!
René van der Starre
