How to update custom iProperties with VBA?
JDidrik
JDidrik
I am trying to write an simple VBA code which gives me the opportunity to automatically export the dimensions of the part to custom iProperties, but when the iProperty has been created the first time, I am not able do update/overwrite the property with updated values. Could someone explain to me what I need to do?
Jan Didrik
MechMachineMan
vb.net is easier to use for accessing properties due to the try catch statement:
Try oProp = oDoc.PropertySets.Item("Inventor User Defined Properties").Item("DESCRIP" & m)
Catch oProp = oDoc.PropertySets.Item("Inventor User Defined Properties").Add("", "DESCRIP" & m) End Try
To do the same thing in vba, you have to scratch the try catch clause and add in either error handling, or a check to ensure the property exists/doesn't.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
rossano_praderi
Hi Jan,
you mean something like this?
Sub ChangeIprop()
    Dim oDoc As Document
    On Error Resume Next
    Set oDoc = ThisApplication.ActiveDocument
    oProp = oDoc.PropertySets.Item("Inventor User Defined Properties").Add("", "DESCRIPTION")
    oDoc.PropertySets.Item("Inventor User Defined Properties").Item("DESCRIPTION").Value = "test"
End Sub
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
JDidrik
Rossano,
I believe thats exactly what I am looking for, but I can not get it to work. See my code below. If the xRange iProperty does not exist, then I am amble to add it. But if it allready exists, I am not able to upadate it.
Public Sub UpdateRangeParameters()
' Get the active part document.
Dim invPartDoc As PartDocument
Set invPartDoc = ThisApplication.ActiveDocument
Dim totalRange As Box
Set totalRange = invPartDoc.ComponentDefinition.RangeBox
Dim xSize As String
Dim ySize As String
Dim zSize As String
xSize = invPartDoc.UnitsOfMeasure.GetStringFromValue(totalRange.MaxPoint.X - totalRange.MinPoint.X, kDefaultDisplayLengthUnits)
ySize = invPartDoc.UnitsOfMeasure.GetStringFromValue(totalRange.MaxPoint.Y - totalRange.MinPoint.Y, kDefaultDisplayLengthUnits)
zSize = invPartDoc.UnitsOfMeasure.GetStringFromValue(totalRange.MaxPoint.Z - totalRange.MinPoint.Z, kDefaultDisplayLengthUnits)
' Get the custom property set.
Dim customPropSet As PropertySet
Set customPropSet = invPartDoc.PropertySets.Item("Inventor User Defined Properties")
'X-RANGE
' Attempt to get an existing custom property named "xRange".
Dim xRange As Property
Set xRange = customPropSet.Add(xSize, "xRange")
If Err.Number <> 0 Then
' Property does not exist -> Add the property. Call customPropSet.Add(xSize, "xRange") Else 'Property exist -> update the value. invPartDoc.PropertySets.Item("Inventor User Defined Properties").Item("xRange").Value = "test" End If MsgBox ("Custom iProperties updated") End Sub
Jan Didrik
Owner2229
Hi, I have no idea how it could work for creation of the new iProperty, but you had a misstake in your code.
As I believe, there should be "User Defined Properties" instead of "Inventor User Defined Properties".
Atleast it works like that for me.
See the corrected version:
Dim xSize As String
Dim ySize As String
Dim zSize As String
Set customPropSet = invPartDoc.PropertySets.Item("User Defined Properties")
'X-RANGE
Set xRange = customPropSet.Item("xRange")
' Property does not exist -> Add the property. Call customPropSet.Add(xSize, "xRange") Else 'Property exist -> update the value. xRange.Value = "test" End If MsgBox ("Custom iProperties updated") End Sub
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
JDidrik
Thanks Mike!
You found the problem. The problem was the "set xRange = customPropSet.Add."
When I changed the code from:
'X-RANGE
to your correction:
'X-RANGE
it now works as intended.
Thanks a lot!
Jan Didrik
