How to test the marking menu ?
TONELLAL
TONELLAL
I need to modify the marking menu, but only if a given command is already in it. So I need to test if this command exist in the marking menu. The problem is that the command exist or not, for inventor it always exist ! Here the code I use to test it :
Private Sub oUserInputEvents_OnLinearMarkingMenu( _
ByVal SelectedEntities As ObjectsEnumerator, _
ByVal SelectionDevice As SelectionDeviceEnum, _
ByVal LinearMenu As CommandControls, _
ByVal AdditionalInfo As NameValueMap)
dim test as boolean
'Test on an existing command
test = LinearMenu.item("Delete") Is Nothing
'Test on a non-existing command
test = LinearMenu.item("Deletesdfgdsfg") Is Nothing
End Sub
In both cases, Test = false
What's wrong ?
WCrihfield
Just a thought, but maybe what you need to check in this situation, instead of 'Is Noting' is the CommandControl.Visible (test = LinearMenu.item("Delete").Visible) , but I don't really know the larger task being dealt with here.  Another probably stupid question...are you sure you need to be working with a LinearMarkingMenu, and not the RadialMarkingMenu?
Wesley Crihfield
(Not an Autodesk Employee)
TONELLAL
 CommandControl.Visible seems to work only in the ribbon. I tried it, fail...
And yes, I need to use the Linear menu and not the Radial menu,  just because the final goal is to replace an existing command.
I found a workaround with a For loop on Control.internalName, but... strange !
Another strange thing about Linear or Radial marking menus :
the command I want to replace is :
-from the browser, only in the linear menu
-from the graphic window, only in the radial menu.
I can find and replace it in both menus, but adding the new command in the radial menu make it appear in the  Linear menu, even when I modify nothing in the linear menu !!
Before menu edition :
After menu edition. I modified ONLY the radial menu, nothing on the linear menu :
The code :
Private Sub oUserInputEvents_OnRadialMarkingMenu(ByVal SelectedEntities As ObjectsEnumerator, ByVal SelectionDevice As SelectionDeviceEnum, ByVal RadialMenu As RadialMarkingMenu, ByVal AdditionalInfo As NameValueMap)
Dim TestCommand As String
'Command to replace
TestCommand = "AFG_FrameMember_Edit"
'Replacing the command if found
With RadialMenu
If .NorthControl.InternalName = TestCommand Then
.NorthControl = oButtonDef_Modifier_fer
End If
If .NortheastControl.InternalName = "TestCommand" Then
.NortheastControl = oButtonDef_Modifier_fer
End If
If .NorthwestControl.InternalName = TestCommand Then
.NorthwestControl = oButtonDef_Modifier_fer
End If
If .SouthControl.InternalName = TestCommand Then
.SouthControl = oButtonDef_Modifier_fer
End If
If .SoutheastControl.InternalName = TestCommand Then
.SoutheastControl = oButtonDef_Modifier_fer
End If
If .SouthwestControl.InternalName = TestCommand Then
.SouthwestControl = oButtonDef_Modifier_fer
End If
End With
Bonus : if you know another way, like "for each control in radialmenu", instead of this... I'm interested !
