How to select the open file in Model Browser?
With this piece of code I am able to select an occurance in the Model Browser.
But not the main assy, like in this picture... how can I do?
Public Sub teer()
Dim oapp As Inventor.Application
Set oapp = GetObject(, "Inventor.Application")
Dim odoc As AssemblyDocument
Set odoc = oapp.ActiveEditObject
Dim oPane As BrowserPane
Set oPane = odoc.BrowserPanes.Item("Model")
oPane.TopNode.BrowserNodes.Item(7).DoSelect
End Sub
YuhanZhang
You can use below code:
oPane.TopNode.DoSelect
 or :
Sub SelectActiveDocTopNode()
     Dim odoc As Document
     Set odoc = ThisApplication.ActiveDocument
     If odoc.DocumentType = kAssemblyDocumentObject Or odoc.DocumentType = kPartDocumentObject Then
         odoc.SelectSet.Select odoc.ComponentDefinition
End Sub
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Thanks Rocky, both work just fine! Smiley Wink
