Component part feature suppression
montylowe
montylowe
im looking for a way to suppress or delete a Component part feature from the assembly level by giving component name ("Part1") and component Feature name ("Hole6") thru the API
Thanks in advance......
montylowe
I figured it out.
My Code
if component is not suppressed then it goes out and suppresses  or unsuppresses the feature based on a switch you send it.
Sub
oCompDef = oDoc.ComponentDefinition
oCompOcc = oCompDef.Occurrences.ItemByName(Comp)
ofeat = iFeature.InventorFeature(Comp, Feat)
Sub ACSFeat(ByVal Comp, ByVal Feat, ByVal SWT)
        Dim oCompDef As Inventor.ComponentDefinition
        Dim oCompOcc As Inventor.ComponentOccurrence
        Dim ofeat As PartFeature
        If oCompOcc.Suppressed = False Then
            If SWT = False Then
                If ofeat.Suppressed = False Then
                Else
            Else
                If ofeat.Suppressed = True Then
                Else
        Else
End Sub
