How to remove the visibility of a solid Body in assembly using Ilogic
caroline_ccc
caroline_ccc
Hello. Is there a way to remove the visibility of a specific solid body of a Part inserted in an Assembly?
If I write a code in the Part file that works, but actually doesn't change anything in the Assembly, the bodies are still there...
How to remove the visibility straight in the assembly file?
johnsonshiue
Hi! A simple Google search leads me to the following thread. Please take a look.
https://forums.autodesk.com/t5/inventor-forum/ilogic-rule-to-change-solid-body-visibility/td-p/73869...
Many thanks!
Software Test Engineer
caroline_ccc
Hello. Thanks for you reply. I already google and found the same link you sent. This is not the case.
The part is inserted in an assembly, as I shown in the picture...
My question is how to remove the visibility of a body of a part inside assembly.
I’d like a code to write Straight in the assembly illogic. Not in the part file.
johnsonshiue
Hi! I am sorry for misunderstanding the request. Try this one instead.
https://forums.autodesk.com/t5/inventor-forum/factory-hide-body-in-asset-via-ilogic-rule-in-assembly...
Many thanks!
caroline_ccc
Thanks for your help. 🙂
This link solved the problem!
