How to remove custom iProperty with iLogic
Message 1 of 20
Hi
I am migrating our old Inventor data to our new system. I will do an ilogic script for that.
I know how to add custom iProperties with iLogic but how can I remove them? Is it possible with iLogic? I would like to clean out all old iProperties that we don't need anymore.
Replies (19)
Message 2 of 20
Curtis_W
Hi TimoVahteri8922,
You can run  this snippet from the part file to remove ALL custom iProperties
'define custom property collection
oCustomPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
'look at each property in the collection
For Each oCustProp in oCustomPropertySet
'delete the custom iProperty
oCustProp.Delete
Next
You can use this snippet if you have a custom property you do not want to delete you can check for it by name, and delete the rest:
'check for a property name that you don't want to delete
If Not oCustProp.name = "HelloWorld" Then
oCustProp.Delete
Else
End If
Next
 You can use this snippet to define a list of properties to keep, and then delete any not in that list:
'define list of custom properties to keep
Dim MyArrayList As New ArrayList
MyArrayList.add("Hello World 001")
MyArrayList.add("Hello World 002")
MyArrayList.add("Hello World 003")
'check property name against the list you don't want to delete
If MyArrayList.Contains(oCustProp.name)Then
'skip it
Else
oCustProp.Delete
End If
Next
 I hope this helps.
Curtis
Message 3 of 20
Thank you! This is just what I needed.
Message 4 of 20
tegstette
Seems like I am looking for a forth kind of snippetSmiley Happy
I need an iLogic-rule that deletes a list of custom properties. I want only the custom properties in my list to be deleted, all other properties I want to keep...
Is there a snippet for this?
I would be very greatful if someone could come up with this...Smiley Happy
Best regards
TG
Autodesk Inventor/Vault Professional 2021
Message 5 of 20
Curtis_W
Hi tegstette,
This rule will delete all of the properties that you add to the list.
I hope this helps.
Curtis
'define list of custom properties to delete
'check property name against the list you want to delete
oCustProp.Delete
Else
'skip it
End If
Next
Message 6 of 20
tegstette
Perfect! Just what I needed! Smiley Happy
Thank you for your quick and kind reply!
Best regards
TG
Message 7 of 20
Hi
 Is it possibyl to delete only the value on custom iproperties?
Message 8 of 20
tegstette
Hi, and thanks so much again for the code you provided me, CurtisSmiley Happy
Worked just perfect in Inventor file by file!
But then I wanted to use this in a batch-job-program (code injector) and I get syntax error, and a message thet says 'oCustProp' is not delared... Now I am a little desperate because I cannot find a solution for it and I have stated a mayjor batch-cleaning-job...Smiley Sad
Here is the code (that works perfectly in Invenor - but not in the batch-program)
MyArrayList.add("TitleFormula")
MyArrayList.add("Tolerance")
MyArrayList.add("bh")
For Each oCustProp In oCustomPropertySet
If MyArrayList.Contains(oCustProp.Name)Then
oCustProp.Delete
Else
'skip it
End If
Next
I attach the errors and warning.
Really hope someone can help me with a quick tip, so I hopefully can proceed our panned job...Smiley Happy
Best regards
TG
Message 9 of 20
Curtis_W
Hi tegstette,
I think you just need to add this line:
Dim oCustProp As Inventor.Property
I hope this helps.
Curtis
oCustProp.Delete
Else
'skip it
End If
Next
Message 10 of 20
tegstette
'Rule 1:
'Delete user Parameter "Each" if exists
Dim oDoc As PartDocument=ThisDoc.Document
Dim param As Parameter
		Try
			param = oDoc.ComponentDefinition.Parameters.Item("Each")
			param.Delete
			Catch
		End Try
'Rule 2:
'If file has AreaFP = SLETT , then delete property AreaFP
		Try
			If iProperties.Value("Custom", "AreaFP").ToUpper = "SLETT" Then
				Dim MyArrayList2 As New ArrayList
				MyArrayList2.add("AreaFP")
				If MyArrayList2.Contains(oCustProp.Name)Then
					oCustProp.Delete
				End If
				Next
			End If
		Catch ex As Exception
		'Here I can add a messagebox
		'MsgBox(ex.ToString)
		End Try
Hi, and thank you for your answerSmiley Happy
I finally found the problem... we have a lot of files with a user parameter (fx-paremeters) that is no longer in use, and this is called "Each" - and it is exported to create a custom property that is called "Each". Problem is that "Each" is also used in the code...:
So I tried to make a rule to delete this user parameter and this works good if this is the only code in the rule, but when the rule continues to the delete customproperties, it seems like it still remembers Each as parameter. So my challenge now is how to "break" this memory... Here is the code.
Can you  help me with at tip?
Best regards
TG
Message 11 of 20
mcloughlin_b
Hi Curtis
Is it possible to get your code to work at the assembly level? In other words delete custom iprops from the top level assembly, all subassemblies, and all parts.
I know about the traverse assembly method but can't figure out how to get things working.
Bryan
Message 12 of 20
Curtis_W
Hi @mcloughlin_b,
Here is a quick iLogic rule that deletes every custom iProperty in every occurrence ( parts and subassemblies) in the assembly. I only did minimal testing, so post back if it does not work.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Iterate through all of the occurrences
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences.AllReferencedOccurrences(oAsmCompDef)
	oCustomPropertySet = oOccurrence.Definition.Document.PropertySets.Item("Inventor User Defined Properties")
	oCustProp.Delete
	Next
Next
Message 13 of 20
mcloughlin_b
HI Curtis
That works great but can it be tweaked to only delete custom props from an arraylist?
Thanks for your time.
Bryan
Message 14 of 20
Curtis_W
Hi mcloughlin_b,
Sure, see the first example below, note I've added the converse of this as well, just in case it's helpful to someone in the future.
I hope this helps.
Curtis
Delete only custom iProps that ARE in the list:
		oCustProp.Delete
		End If
	Next
Next
Delete only custom iProps that are NOT in the list:
		'skip it
		Else
		oCustProp.Delete
		End If
	Next
Next
Message 15 of 20
@Curtis_W Hi Curtis, thanks for the last bit of code. I have tried to tweak it a bit to create two different array lists so that I can perform different actions on each list.
MyArrayList.add("STEEL)
MyArrayList.add("STEEL")
Dim MyArrayList1 As New ArrayList
MyArrayList1.add("PAINT")
		If MyArrayList.Contains(oCustProp.Name) Then
		MessageBox.Show(oOccurrence.ReferencedFileDescriptor.FullFileName & " contains STEEL operations, which will be deleted.", "STEEL Operations")
		oCustProp.Delete
MsgBox(oCustProp.Name & " was deleted") 'Going to add a line here to add a replacement iProp End If 'check property name against the list If MyArrayList1.Contains(oCustProp.Name) Then MessageBox.Show(oOccurrence.ReferencedFileDescriptor.FullFileName & " contains PAINT operations, which will be deleted.", "PAINT Operations") 'delete the custom iProperty oCustProp.Delete
MsgBox(oCustProp.Name & " was deleted") 'Going to add a line here to add a replacement iProp End If Next Next
I ran the code in a simple assembly where the sub part had both iProps present, it notifies me with the first msg box and deletes the iProps but I get this error before the second msg box:
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
Any ideas how I can fix?
Message 16 of 20
Curtis_W
Hi c.rp.Henderson,
As written, I don't see a need for the 2 lists, so I think you can use one list and an  'Else If' to resolve this as in this 1st version:
MyArrayList.add("PAINT")
		oCustProp.Delete
		Else If MyArrayList.Contains(oCustProp.Name) Then
		oCustProp.Delete
		End If
	Next
Next
If the 2 lists are required, then you can add a 'Continue For' line to move on once the first If/Then has executed. I think the error you're getting is because the property is deleted, and then 2nd If/Then condition is looking at that property still. The 'Continue For' should resolve this.
		oCustProp.Delete
		Continue For
		End If
		oCustProp.Delete
		End If
	Next
Next
I hope this helps.
Curtis
Message 17 of 20
martinBV7H5
Observer
Observer
Hi there,
Wonder if you could help me on a similar matter. I've used a custom task in task scheduler to create a custom property across our library in the vault. But now I want to delete a certain property (category) from the custom properties, again using an external rule via the custom task in task scheduler.
Any chance you know how to create a ilogic rule to do this?
Martin
Message 18 of 20
Life and time saver..Great😀
Message 19 of 20
alexander_dolls
Community Visitor
Community Visitor
Hello Curtis,
I tried the version with keeping the iProps in the list.
Unfortunately I get the following error.
(Ausnahme von HRESULT: 0x80004005 (E_FAIL))
Do you have any idea what this could be?
Best regards
Message 20 of 20
alexander_dolls
Community Visitor
Community Visitor
i Forget
MyArrayList.Add("AENDERUNGS_DATUM")
MyArrayList.Add("AENDERUNG_NAME")
MyArrayList.Add("B")
MyArrayList.Add("D")
MyArrayList.Add("L")
MyArrayList.Add("G_L")
MyArrayList.Add("H1")
MyArrayList.Add("H2")
MyArrayList.Add("DATUM_GEZ")
MyArrayList.Add("PTC_WM_ITERATION")
MyArrayList.Add("PTC_WM_LIFECYCLE")
MyArrayList.Add("PTC_WM_LIFECYCLE_STATE")
MyArrayList.Add("PTC_WM_NAME")
MyArrayList.Add("PTC_WM_NUMBER")
MyArrayList.Add("PTC_WM_ORGANIZATION_ID")
MyArrayList.Add("PTC_WM_REVISION")
MyArrayList.Add("TK_AENDERUNGSNUMMER")
MyArrayList.Add("TK_ARTIKELNUMMER")
MyArrayList.Add("TK_DIN_NR")
MyArrayList.Add("TK_ERSATZ_FÜR")
MyArrayList.Add("TK_GEPRUEFT_AM")
MyArrayList.Add("TK_GEPRUEFT_DURCH")
MyArrayList.Add("TK_TITEL")
MyArrayList.Add("TK_TITEL_EN")
MyArrayList.Add("ZEICHNUNGSNR")
			If MyArrayList.Contains(oCustProp.name) Then
			'skip it
			Else
			oCustProp.Delete
			End If
	Next
Next
