how to read name of current LOD
I want to read the name of the LOD that is active and return it via msgbox but it's not working for me?
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim test As String
test = LevelOfDetailRepresentation.Name()
MessageBox.Show("Message" & test, "Title")
whats not correct?
I found this on the forum:
currentLOD = ThisDoc.Document.ComponentDefinition.RepresentationsManager.ActiveLevelofDetailRepresentation.Name
But i get "Error on Line 1 : End of statement expected."
MegaJerk
The simplest way would probably be :
MessageBox.Show(ThisDoc.Document.LevelOfDetailName)
You could also do something like this if you wanted to, but it wouldn’t be that great for sub-assemblies :
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
       Return
End If
Dim assemblyDoc As AssemblyDocument
assemblyDoc = ThisApplication.ActiveDocument
MessageBox.Show(assemblyDoc.LevelOfDetailName)
If you wanted to be dangerous you could just do :
MessageBox.Show(ThisApplication.ActiveDocument.LevelOfDetailName)
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
