How to put iFeature on workplane
Hi,Everyone.I have a serious problem recently. I want to put my iFeature on my workplane,but i can't.
However, if I change my PlaneInput = oFace , it can work perfectly.My program is below:
Private WithEvents oInteraction As InteractionEvents
Private WithEvents oselect As SelectEvents
Private Sub UserForm_Initialize()
    Set oInteraction = ThisApplication.CommandManager.CreateInteractionEvents
    Set oselect = oInteraction.SelectEvents
    oselect.AddSelectionFilter kPartFaceFilter
    oselect.SingleSelectEnabled = True
    oInteraction.Start
End Sub
Private Sub oselect_OnSelect(ByVal JustSelectedEntities As ObjectsEnumerator, ByVal SelectionDevice As SelectionDeviceEnum, ByVal ModelPosition As Point, ByVal ViewPosition As Point2d, ByVal View As View)
    Dim oFace As Face
    Set oFace = JustSelectedEntities.Item(1)
    On Error Resume Next
    Dim oPartDoc As PartDocument
    Set oPartDoc = ThisApplication.ActiveDocument
    If Err Then
        MsgBox "A part must be active."
        Exit Sub
    End If
    Dim oPartDef As PartComponentDefinition
    Set oPartDef = oPartDoc.ComponentDefinition
    Dim oFeatures As PartFeatures
    Set oFeatures = oPartDef.Features
    'Give a offset to oFace
    Dim oWorkPlane As WorkPlane
    Set oWorkPlane = oPartDef.WorkPlanes.AddByPlaneAndOffset(oFace, 0.5, False)
    ' Create an iFeatureDefinition object.
    Dim oiFeatureDef As iFeatureDefinition
    Set oiFeatureDef = oFeatures.iFeatures.CreateiFeatureDefinition("D:\Document\\130812\countersink\countersink.ide")
    ' Set the input.
    Dim oInput As iFeatureInput
    For Each oInput In oiFeatureDef.iFeatureInputs
        Dim oParamInput As iFeatureParameterInput
        Select Case oInput.Name
            Case "sketch plane"
                Dim oPlaneInput As iFeatureSketchPlaneInput
                Set oPlaneInput = oInput
                oPlaneInput.PlaneInput = oWorkPlane               ' it doesn't work!!!!!!!!!!!!!!!!!!!!!!!!!!
            Case "size"
                Set oParamInput = oInput
                oParamInput.Expression = "M5"
        End Select
    Next
    ' Create the iFeature.
    Dim oiFeature As iFeature
    Set oiFeature = oFeatures.iFeatures.Add(oiFeatureDef)
End Sub
Private Sub oInteraction_OnTerminate()
    Set oselect = Nothing
    Set oInteraction = Nothing
    Unload Me
End Sub
Thanks a lot in advance
xiaodong_liang
Autodesk Support
Autodesk Support
I tested with a selected face directly. It works well. The attachments are the test snapshots and my iFeature. If you still have the proble, please isolate and send run-able code and neccesary iFeature ide. Code snippet does not always help
Sub test()
   Dim oFace As Face
    Set oFace = oPartDoc.SelectSet(1)
    Set oiFeatureDef = oFeatures.iFeatures.CreateiFeatureDefinition("c:\temp\iFeature1.ide")
    ' Set the input.
            Case "Profile Plane1"
                Debug.Print "OK!"
            Case "size"
        End Select
    Next
End Sub
